1968 L89 build sheet
Old Aug 11, 2025 | 06:23 PM
LadderPig's Avatar
LadderPig
Default 1968 L89 build sheet
If a build sheet can be safely removed from the top of the tank, should this be done or not? If removed to read, should it be placed back in original position or safely preserved? Thanks in advance.
Old Aug 11, 2025 | 07:11 PM
Corey_68's Avatar
Corey_68
I would take many pictures prior to the attempt to remove. If you can anticipate it can be safely removed, I would and preserve it off the car.
Old Aug 11, 2025 | 07:40 PM
Alan 71's Avatar
Alan 71
Hello,
'68 L89 !!!!!
Pretty NICE!
The sheet will likely be VERY fragile.
Once you have access to it you may want to begin by dusting it off with a soft make-up brush like the ones the ladies use on their cheeks.
Good Luck.
Regards....
Old Aug 11, 2025 | 08:25 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if its stuck to the tank. just cut the tank around the sheet to save it
To 1968 L89 build sheet
