adding a vacuum pump
Old Sep 2, 2025 | 02:57 PM
gccch's Avatar
gccch
Default adding a vacuum pump
On my 70 BB I am interested in adding a vacuum pump just to be sure I have vacuum at idle for brake booster and lights & wiper cover. I'm looking for recommendations for a reliable electric vacuum pump that I can mount somewhere out of sight and put that system aside for the time being. I will continue to work on solving my vacuum issues, but need something I can rely on for the near term as I need to use the car.
Old Sep 2, 2025 | 07:20 PM
ignatz's Avatar
ignatz
I once researched this but never did anything. Here's a forinstance:
https://www.corvetteforum.com/forums...onversion.html
Old Sep 2, 2025 | 10:52 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
This method might save you $$$.......(Members please advise if the method below will not work)
"Ultimately, a modified AC compressor can produce 28Hg (28 lbs.) be a very effective and low-cost alternative for applications,"
You could wire the a/c clutch to an12VDC vacuum switch mounted on the vacuum reservoir
so the unit would engage the clutch at a level set by you. The unit would not run constantly, but would keep the HG level constant.
You can buy a a/c compressor and hose with bracket for less than $50 at a late model salvage yard.
Get a friend to modify the bracket to fit your engine if you don't have that skill level.
Old Sep 3, 2025 | 07:54 AM
gccch's Avatar
gccch
Interesting idea with the AC pump, but I would rather not put another belt on the engine. There are a lot of options for electric pumps and it's been mentioned here before. I figure there are some already completed that may have some advice on those.
Old Sep 3, 2025 | 09:06 PM
majorbob's Avatar
majorbob
I just got a 73 with high lift, long duration cam that has a summit racing 12v vacuum pump. Seems to work fine with the 383 thumper under the hood;, headlights and wipers work fine
Old Sep 4, 2025 | 03:55 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I had 2 different ones when I had about 13 to 15 inches i used a little Hella pump that came with a remote shutoff at a set point, it was loud but small. When I put in a different induction system that had only 10 inches of vacuum I got a Leeds vacuum pump that is designed for brakes only. It came with a plastic cover and it was huge. I ended up just running the pump. If yo can hid them in front of the radiator or all the way in back near the spare tire tub but you will be running a long vacuum line. Its quieter than the Hella vacuum pump. I still use that fo rmy headlights
Old Sep 4, 2025 | 10:10 PM
ignatz's Avatar
ignatz
Should have asked this previously, do you have a vacuum tank that doesn't leak? Worked pretty well for me over the years.
Old Sep 6, 2025 | 10:04 AM
gccch's Avatar
gccch
I'm not sure about that. I have ordered a vacuum gauge so I can also troubleshoot the reservoir.
Old Sep 6, 2025 | 10:10 AM
gccch's Avatar
gccch
Looking at this one from amazon. Seems a little large at 10-1/2" overall length. Maybe hiding in the rear is possible. I hate adding something like this to a mostly unmodified and original car but I need this stuff to work and don't have much time to try other solutions.
Amazon Amazon
Old Sep 6, 2025 | 01:25 PM
ignatz's Avatar
ignatz
Do you also need to add a catch can with this? Seems a bit much.
Old Sep 10, 2025 | 08:16 PM
Noltz's Avatar
Noltz
I'll mention that many modern vehicles are coming with vacuum pumps from the factory due to low vacuum at idle (increases pumping efficiencies, better emissions numbers). Caravans and Wranglers come to mind, and they're electric, fairly small and quiet. Just something to think about.
Old Sep 12, 2025 | 07:04 AM
gccch's Avatar
gccch
I haven't opened the box yet. With timing adjusted it is behaving a little better, but the wiper door is still opening when idling. I'm going to trouble shoot the vacuum system next and go from there.
Old Sep 15, 2025 | 08:59 PM
gccch's Avatar
gccch
I ended up returning the pump. The check valve at the reservoir was found to be passing air in both directions. So I need to replace that before and recheck the system before doing anything dramatic.
Old Sep 21, 2025 | 12:01 AM
hydrasport's Avatar
hydrasport
I had the same idea as I intend to install a decent cam in the 350 small block that will be getting rebuilt. I have been dealing with the original, nonfunctioning wiper cover today. I also started checking for vacuum leaks and dug into the headlight vacuum system. Then I found an electric conversion kit for the headlight door system for less than $100 on Ebay. They also sell an electric wiper cover conversion for about $390 on Ebay and that manufacturer's kit has been talked about on this forum before. His kit has good reviews. I know this may not be the answer that you are looking for, but before I spend good money for an electric vacuum pump, I would think removing some of the load on the OEM vacuum system might help send more volume to the brake booster.
Old Sep 21, 2025 | 06:54 AM
Rescue Rogers
Thats not how vacuum works. If you have 10 inches of vacuum, thats it. Everywhere sees the 10 inches. He has to either add pumps to increase it or go electric. Leeds makes an electric pump that is brake booster only and i saw someone else had a link to another company. The brakes need a higher volume vacuum pump for quicker recovery. Vacuum accessories are one and done ....turn on headlights , doors open and they stay there for the trip..
Old Sep 21, 2025 | 05:33 PM
Lobzila's Avatar
Lobzila
I had a similar experience with vacuum pumps. The one I put in was loud! Ended up changing it out and going the electric route. Best decision I ever made on this.
To adding a vacuum pump
