Windshield Frame Lower Corner Replacement
Old Oct 16, 2025 | 11:00 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Default Windshield Frame Lower Corner Replacement
Both inner and outer lower corners of my '71 coupe were badly rusted and needed to be replaced. I didn't want to remove the entire fender to gain access and I'd heard that some people had accomplished the task by just remocing the upper tip of the fender, so I set out to do it that way too. I didn't find much info on exactly how to do it and what was involved, but posts from member Arg0413 in his 1971 LT-1 Resurrection thread helped. I hope this thread will provide lots of specific information to help others who might be facing a similar situation...
Inner corner rusted through
Inner corner was rusted through
Inner donor replacement
Inner corner donor replacement
Inner corner damage & replacement piece shown from outside
Outer corner damage shown with inner corner removed
Closeup of outer corner damage
Outer corner replacement piece
Outer corner replacement piece. The upper curve and raised flat portion of 68-72 corners are different from 73+ and are not available from the vendors. I was lucky to seure this one.
Rusted pieces thgat were removed
Remains of rusted pieces that were removed
What is left after inner & outer metal corners are removed
Scraping tool and heat was used to break the glue holding the fender to its bonding assembly.
Scraping tool and heat was used to break the glue holding the fender to it's bonding assembly.
Splitting fender from underlying bonding assembly
Once the upper fender tip was cut and removed, its bonding assembly was revealed.  Its attached to the metal outer corner with 3 rivets.
Once the upper fender tip was cut and removed, its bonding assembly was revealed. It's attached to the metal outer corner with 3 rivets.
Fender cut was made shallow in the bonding strip area so the lower assembly wouldn't be damaged. When I finally cut the bonding assembly I left about an inch of the bonding strip exposed to aid in the fender tip reattachment.
After the bonding assembly was cut and removed, damage to the hinge pillar was revealed.
Hinge pillar from my donor assembly showed similar damage
Pillar rust hole was enlarged a bit and a small patch piece was welded in.
"While I was at it," I also welded up the access hole in the side of the windshield side frame. Hopefully this will prevent any future water intrusion.
Lower side frame holes welded up
More to follow...
Old Oct 17, 2025 | 06:16 AM
ACfarmerNH's Avatar
ACfarmerNH
Big project and good photos for those contemplating doing it in the future. Thanks
Old Oct 17, 2025 | 08:41 AM
Alan 71's Avatar
Alan 71
Hello,
Thank you for taking the time to take the photos and post them.
Your photos show what a serious piece of work you're doing!!!
Nice!
I think it might be helpful to post some photos that have the camera pulled back a little to give a better sense of just how all these pieces fit together as you progress.
Again ,thank you!!!
Regards.....
Old Oct 17, 2025 | 12:47 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
You're welcome - hopefully it will help others
Originally Posted by Alan 71
Hello,
Nice!
Again ,thank you!!!.
Regards.....
Thanks Alan. I'm honored to get a compliment from you! Unfortunately, except for filling the gap on the fender cut, the progress on this is finished. I took photos as I went along and waited until now to start the thread. Most are close ups to show detail, but as I continue the thread I'll look for pics that may show better views of how it all went together.
Old Oct 27, 2025 | 12:19 PM
Lord Melbury's Avatar
Lord Melbury
Hi, posting some pictures from my windshield frame repair
LH corner seems to be bad
RH looks better
Rust in the upper corners and frame as well
Front clip and firewall removed for better acess
Replacement parts was ordered from U$
Reinforcements added to keep the pillars in place
LH pillar repair
LH completed with parts from old corner and new 73-
RH much better, just a pinhole in the inner corner
Welding completed, now some clean up and then epoxy and paint
Old Oct 27, 2025 | 06:07 PM
Alan 71's Avatar
Alan 71
Hello,
WOW!!!
Serious work you've done there.
Now that's RESTORATION!!!
Regards...
PS: With all that rust in the cowl what do the bottom of the hinge pillars look alike?
I'd think that water had to go somewhere?
Old Oct 27, 2025 | 08:12 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Nice job, but that sure looks like it was a TON of work! I'm glad mine wasn't so bad that I would've had to remove the entire front clip like you did.
Old Oct 28, 2025 | 12:29 PM
Lord Melbury
Thanks Alan, I was lucky, no further rust in the bottom of the hinge pillars or birdcage. Just some surface rust, easy to clean and treat with rust converter and paint.
Old Oct 29, 2025 | 01:28 AM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Of course "life" gets in the way of working on vettes, but it also gets in the way of posting on this forum. I've finally found the time and gumption to continue with this 'how I did it' thread...
Lord M showed the "conventional" way to do these lower windshield corner repairs by removing the entire front clip to get access. My intent is to show another less intrusive way if the rust damage is not too extensive. I think that just removing the upper corner of the fender is easier BUT it does introduce the need reattach the cut piece back into the proper position and then deal with ensuring that the cut doesn't telegraph itself through the finish paint.
While researching how to do my repair, I had a difficult time finding out the exact shape of the bonding panel that supports the upper fender tip. I didn't find any good pictures of the support on the forum or the vendors' parts diagrams. So to ensure I had a good plan for how to make the fender cut and placing it where it could be reattached fairly easily, I had to use lights, mirrors, and my sense of touch reaching under the fender from the wiper bay to determine the bonding assembly shape.
Here is the bonding support piece exposed after the fender tip was removed.  Its attached to the metal outer corner with the 3 blind rivets shown.  The actual bonding surface is shaped like the #7.
Here is the bonding support piece exposed after the fender tip was removed. It's attached to the metal outer corner with the 3 blind rivets shown. The actual bonding surface is shaped like a #7.
This view angle shows the vertical(ish) bonding surface (A) of the support piece.  Item B is the side edge of the metal outer corner that in this shot has been bent down & outward so I could better visualize the structure and rust damage.
This view angle shows the vertical(ish) bonding surface (A) of the support piece. Item B is the side edge of the original metal outer corner that in this shot has been bent down & outward so I could better visualize the structure and rust damage.
This shot was taken after the inner and outer metal corners were removed and the fender cut made.  It shows the bonding support piece (C) and the 3 rivet holes, the hinge pillar where it merges into the windshield side frame (A) and the rear vertical portion of the wiper trough (B).  You can see the two rivet holes where B was riveted to the metal outer corner piece.
This shot was taken after the inner and outer metal corners were removed and the fender cut made. It shows the bonding support piece (C) and the 3 rivet holes, the hinge pillar where it merges into the windshield side frame (A) and the rear vertical portion of the wiper trough (B). You can see the two rivet holes where B was riveted to the metal outer corner piece. D is the fender cut itself.
Top view of the bonding panel piece.  Fender cut is visible along bottom of photo.  Just below and slightly left of the 3 rivet holes the top edge of the wiper trough rear vertical wall is also visible.
Note that the fender cut was made shallow in the area where it was over the bonding strip so as to not cut the strip itself. I did this to keep the bonding support piece as rigid as possible to better aid reassemble and because I still wasn't sure of the shape of the assembly down near the floor of the wiper trough and how it was attached in that area. Once the fender was cut and removed, I was able to better see the details of the bottom of the support assembly and determine where to cut that to gain access to the metal outer corner piece once the 3 rivets were removed. Both the fender cut and the cut to the underlying bonding support were made using a cutoff wheel on an air grinder.
This shows were the fender cut was made.  After viewing the underlying support assembly, I wish I would have made the cut closer to where the red line is.  That wouldve given me better access to the lower forward edge of the metal outer corner where it goes across and down the hinge pillar.
This shows were the fender cut was made. After viewing the underlying support assembly, I wish I would have made the cut closer to where the red line is. That might've given me better access to the lower forward flange of the metal outer corner where it goes across the top of the hinge pillar but may have also required cutting aportion of the wipoer trough also.
Photo of my outer corner replacement piece. My cut didn't give good access to plug weld this small circled portion of flange across the top of the hinge pillar. I welded up the holes where the spot welds were cut out in this area to strengthen the flange here before it bends vertically down the inside of the hinge pillar.
The top of my cut was 6
The top of my cut was 6" from the rear inner corner tip while the bottom was 8" from the rear outer tip. A better cut line might've been 7.5" and 10" respectively or somewhere in between
After removing the fender tip, I was able to visualize where to cut the bonding support piece.
Where to cut the bonding support to provide the best access to the outer corner while still be able to reattach it so as to provide the best support to the fender tip when it is reattached?
Blue line 2 is where I cut the bonding support piece.  Yellow line 1 is the fender cut.  Red line 3 is the top edhge of the vertical rear portion of the wioer trough.
Blue line 2 is where I cut the bonding support piece. Yellow line 1 is the fender cut. Red line 3 is the top edhge of the vertical rear portion of the wiper trough.
Close up shows 1 - fender cut, 3 - wiper trough and 4 - metal outer corner flange.  2 is the remaining portion of the bonding support piece after it was cut.
Close up shows 1 - fender cut, 3 - wiper trough and 4 - metal outer corner flange. 2 is the remaining portion of the bonding support piece after it was cut. A small piece of 3 was removed to allow a plug weld just above the #4.
Another view of the bonding support piece cut line
Another view of the bonding support piece cut line. Had I made the fender cut more forward, I would've been able to also cut the bonding support piece further forward also, but that small flange portion of the metal outer corner that was circled in a previous photo still would've been covered by the wiper trough and I didn't want to have to cut that also
The cut piece of the bonding support assembly
The three rivet holes in the bonding support piece didnt match the three holes in the replacement couter corner.  The holes in the support piece were filled with VPA and then new holes were drilled to mate with the existing holes of the replacement corner.
The three rivet holes in the bonding support piece didn't match the three holes in the replacement outer corner. The holes in the support piece were filled with VPA and then new holes were drilled to mate with the existing holes of the replacement corner.
To ensure the cut fender tip piece could be reattached back in its exact correct position without worrying about the width of the cutting disc, I figured out a way to premake a bonding strip held in position with cleco clips BEFORE the fender cut was actually made. This would allow the fender tip to be cut without the new bonding strip in place. Then the strip could be glued to the stationary fender using clecos to hold it in place. After that, the cut fender tip could be glued to the new bonding strip and the olriginal underlying bonding support assembly using the clecos to hold it in the proper position.
Fender covered with foil to prevent fiberglass resin from sticking to it
A few layers of glass matt and resin formed the bonding strip with the proper curve
Strip shape was trimmed to fit on the underside of the fender then holes were drilled through the strip and the fender to allow placement of the cleco clips
The holes didnt line up when the bonding strip was moved to the underside of the fender.  Therefore, the bonding strip was held in position under the fender while new holes in the strip were drilled using the previously drilled fender holes.
Unfortunately, the holes didn't line up when the bonding strip was moved to the underside of the fender. Therefore, the bonding strip needed to be held in position under the fender while new holes in the strip were drilled using the previously drilled fender holes.
This resulted in two sets of holes in the bonding strip, but they didnt impact the strips integrity and wont be seen.
That resulted in two sets of holes in the bonding strip, but they didn't impact the strip's integrity and won't be seen.
Bonding strip held to fender with clecos
Bonding strip on fender tip
Bonding strip held on fender tip with clecos
To be continued again...
Old Nov 25, 2025 | 08:17 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
OK, I'm back from vacation and it's finally time to finish this story!
Outer corner clamped into place
Outer corner plug welded in
Anti-rust treatment & plastic wedge applied
Fender tip and bonding support piece glued back together in using remaining original placement markings.  Tape held some small self-made fiberglass bonding tabs that will be used to mate it to the fixed remaining support structure that is still in place
Fender tip and bonding support piece clamped back together using remaining original placement markings. Tape positioned some small self-made fiberglass bonding tabs that will be used to mate it to the fixed remaining support structure that is still in place. This was done in order to be able to position the support piece properly so the 3 rivet holes could be drilled in it to match 3 holes in the outer corner.
Small bonding tabs for joining support structure
Small bonding tabs for joining the cut support structure to the fixed structure
Bonding piece clecod to fixed fender
Bonding piece cleco'd to fixed fender
Then cut fender clip with support structure clamped underneath was clecod in place
Then cut fender tip with support structure clamped underneath was cleco'd in place
Temporarily mounting the support structure in place allowed me to re-drill the 3 rivet holes in it from underneath
3 redrilled rivet holes in the mounting structure
3 redrilled rivet holes in the mounting structure show the different hole placement between those of the old and new outer corners
Mounting structure was then riveted onto the outer corner.  A bonding tab (under the spring clamp) was used to secure the cut pieces bonding edge to that of the fixed support structure.
Mounting structure was then riveted onto the outer corner. A bonding tab (under the spring clamp) was used to glue the cut piece's bonding edge to that of the fixed support structure.
Once all the outer corner work was done, I could then finish replacing the inner corner...
Weld-through primer was applied to flanges that were to be plug welded.  Anti-rust paint was applied to the rest of the inner corner.
Inner corner clamped into place
Inner corner plug welded on
Gusset clamped into position for welding
Finished inner corner and gusset
Inner corner and gusset were then painted
Old Nov 25, 2025 | 09:19 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Next up was to finish joining the cut bonding/support piece back to the remaining fixed structure...
Self made bonding strip was glued in to connect the fixed and cut bupport bonding flanges.
Self-made bonding strip was glued in to connect the fixed and cut support bonding flanges.
Foil was wedged under the gap between the fixed and cut support pieces as backing for the application of VPA
In places where the small bonding tabs weren't practical, foil was wedged under the gaps between the fixed and cut support pieces as backing for the application of VPA
Edges of the cut were beveled before the VPA was added
VPA sealed the gap nicely and sanded down well considering it wont be seen.  The gap in the bonding flange at the bottom of the photo was filled with VPA later.
VPA sealed the gap nicely and sanded down well considering it won't be seen. The gap in the bonding flange at the bottom of the photo was filled with VPA later.
After the bonding support pieces were rejoined, actually reattaching the cut fender tip was next on the agenda...
Glue was applied to half of the fender cut bonding strip which was then clecod into position then clamped.
Glue was applied to half of the fender cut bonding strip which was then cleco'd into position then clamped.
Once that adhesive set up, the cut fender tip was ready to be glued back into place.  Adhesive would be applied to the fabricated bonding strip and the #7 shaped bonding flange of the support structure.
With the adhesive applied, the cut fender tip was clecod into position and glued edges were clamped
With the adhesive applied, the cut fender tip was cleco'd into position and glued edges were clamped
Edges of the joined cut were beveled for the VPA
First VPA application still had some low spots
First VPA application had some low spots
2nd VPA layer still left a bit of a low spot at the bottom edge
2nd VPA layer still had low spots
"Finished" cut repair feels smooth, but it will be readdressed when the entire car is stripped and ready for final painting prep...
Only time will tell if this repair turns out OK. Regardless of that, I hope the info in this tread might help anybody else contemplating using this method of replacing the lower windshield corner without removing the entire front clip!
Old Nov 26, 2025 | 01:52 AM
68/70Vette's Avatar
68/70Vette
Going back to the photos showing restoration of the windshield frame. Since you're going to have to buy a new windshield, I would have bought the windshield before starting the welding/replacing of new sheet metal parts. This way I would have been sitting the glass into the frame as I made the repair to make sure the windshield glass fit exactly. It needs to lay in the metal frame, and before adding foam damn strips to the glass, make sure that the glass touches the metal frame equally around it's entire perimeter. I replaced my windshield glass and I was surprised how close and exact the glass fits in the metal frame. As you weld in pieces and rebuild the frame this exact fit can then be duplicated as you complete the repair.
Old Nov 26, 2025 | 05:29 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Good points that I hadn't worried about - or even thought about actually. I only had to replace the driver's lower corner and since the rest of the windshield frame was rigidly held in place (both upper corners solid, coupe center T-bar, and both hinge pillar connections), I wasn't too worried that anything would shift enough to affect the fitment of the replacement glass. The lower frame stayed firmly riveted to the wiper trough structure and there was a locating hole in the outer corner that ensured proper placement onto the hinge pillar/windshield side frame. I was fairly confident that the windshield mating surfaces remanined in their proper positionings. With what you mentioned, I'm hopeful that the glass will lay correctly.
Green punch through outer corner locating hole into hinge pillar ensured proper placement.
Circled area was the only glass mating surface that was replaced and existing fixed structure on both ends hopefully ensured proper placement.
Onve outer corner was welded back in, inner corner only provides support - no glass mating surfaces.  Alignment of access holes in both the hinge pillar and inner corner provided positioning cues.
Once outer corner was welded back in, inner corner only provides support - no glass mating surfaces. Alignment of access holes in both the hinge pillar and inner corner provided positioning cues.
Old Nov 28, 2025 | 12:02 PM
68/70Vette's Avatar
68/70Vette
.......................... The lower frame stayed firmly riveted to the wiper trough structure and there was a locating hole in the outer corner that ensured proper placement onto the hinge pillar/windshield side frame. I was fairly confident that the windshield mating surfaces remanined in their proper positionings. .....................
Green punch through outer corner locating hole into hinge pillar ensured proper placement......................
Thanks for all of this extra information, things I didn't know before. Also, the photos also.
Old Nov 28, 2025 | 11:09 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
You're welcome. Hope you find it all of some use...
Old Nov 28, 2025 | 11:26 PM
Tuna Joe's Avatar
Tuna Joe
https://cscreproductions.com
Another source for window corners and other body parts. In fact, I believe these guys make a lot of the parts for the big box corvette stores
Old Dec 1, 2025 | 11:58 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Thanks, I wish I had found them years ago when I was searching for corners for my '71. At the time, all I could find were corners for 73 and later cars...
Old Dec 2, 2025 | 10:31 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
Agreed.
I have never seen new 68-72 windshield corners before!
Great find!
To Windshield Frame Lower Corner Replacement
