New member
Old Nov 6, 2025 | 11:24 PM
OldCarBum's Avatar
OldCarBum
Congratulations on the new Corvette and welcome to the forum.
Try driving it for a while before you start throwing performance parts into it.
See where you want more torque and power and plan your performance package from there.
Keep in mind everything needs to work together from the camshaft specs to the head choices to the rear end gearing to make it perform the way you want it to.
You can easily throw a ton of money into it and end up with a real dog.
Even something as simple as your header choice is very important.
Primary tube diameter, tube length, collector diameter, exhaust tube diameter and mufflers can make a real difference.
You might even find that an X or H pipe in the system isn’t what you want.
Old Nov 7, 2025 | 11:33 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by ZIOGEO
Nassau County or east end?
North Shore Suffolk
Old Nov 7, 2025 | 02:11 PM
Dmac55's Avatar
Dmac55
Cruising
At persent I am still working on the master cylinder replacement. Got a generic master cylinder that had 4 ports two of which you plug. First one I could not get the plug closest to mount to seal so I returned , second one did the same thing, decided to go to local auto parts for third that one someone else had purchased and returned shipping plugs missing and fluid in plastic bay returned. fourth master bench blead and ready to install. checking the gap on power booster showed adjustment needed must be a lot of locktite on threads can't get nut to turn with plyers and wrench time for vice grips and wrench. Had to take a break.
Old Nov 8, 2025 | 12:56 AM
ZIOGEO's Avatar
ZIOGEO
Originally Posted by 427SIXPACK
North Shore Suffolk
Ah. My first job after graduating SUNY Farmingdale was in Smithtown. I drove against the traffic, but into the glaring sunlight. Both ways.
Old Nov 8, 2025 | 01:02 AM
ZIOGEO's Avatar
ZIOGEO
For some Corvette specific parts you might save some headache and check the usual Corvette parts suppliers first like Zip or Top Flight. For generic stuff like spark plugs or filters, the local Napa is fine, but in my experience they will let you down with parts that are C3 Corvette specific. Hopefully the one you have now will get you across the finish line.
Old Nov 8, 2025 | 11:09 AM
427SIXPACK's Avatar
427SIXPACK
Buy the "CORRECT" parts. You won't waste your time, & you will have the correct fit & finish without the headaches.
CLICK HERE >>>>>>>> https://www.cssbinc.com/
Old Nov 8, 2025 | 06:23 PM
bigblock427's Avatar
bigblock427
Congratulations on a nice looking Vette.
Welcome to the Forum.
Old Nov 20, 2025 | 07:41 PM
Dmac55's Avatar
Dmac55
Cruising
Finished bleeding the brakes and finally got to drive the car. Took theT-tops off for the first time and went for a drive. It was a nice drive even in traffic, great to be back on the road.
Old Nov 20, 2025 | 07:58 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Next trip bring the cammmmraaa!
Old Nov 20, 2025 | 10:30 PM
OldCarBum's Avatar
OldCarBum
Congratulations!
