72 corvette ignition delimma
Old Nov 17, 2025 | 07:48 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
I'd believe that but question if that is that the same AI that told me not to sleep for 24-36 hours after scuba diving???
Old Nov 17, 2025 | 11:39 PM
Peterbuilt's Avatar
Peterbuilt
See post #5 by Rebelyell.
He is correct that the ballast resister wire limits current not voltage.
Your typical VOM meter will only average the power because it cannot keep up as the points open and close.
AI is incorrect when stating it limits voltage.
See the sticky by 69427.
Old Nov 18, 2025 | 05:27 PM
C8H18's Avatar
C8H18
While the intent of a resistor wire or ballast resistor is to reduce current to the coil, it has the complementary effect of also reducing voltage. To check for voltage drop at Coil+ with a typical meter: With engine OFF (not running) and key in RUN position with the points CLOSED. (however you should not leave the key in the ON position with points closed for very long.)
Old Nov 19, 2025 | 08:19 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Rebelyell and Peterbuilt are correct in their posts.
Regarding the voltage drop, it's a constantly changing amount, and as mentioned, a voltmeter can't keep up, and will just give a rough average of things.
During the 15* of non-dwell, there is 12-13 volts at the coil C+, and that same 12-13 volts across the coil primary windings right after the points close, and then that C+ voltage ramps down to about 6-7 volts right before the points open, and then when the points open the voltage across the primary spikes up 100-200 volts at the C- terminal when the plug arcs.
An oscilloscope shows all this, but is pretty much overkill for most owners needs, and a voltmeter will give a sufficient brute force average voltage at the coil.
Old Nov 21, 2025 | 02:01 PM
C8H18's Avatar
C8H18
If you (carefully) follow the steps outlined in post #23 - the voltage drop will most certainly Not be constantly changing. A simple VOM meter that most any DIYer likely owns is all that's needed to measure voltage drop (along w/ a screw driver to crack open the distributor).
No Oscope or convolutions necessary.
Old Nov 30, 2025 | 12:11 PM
sameold01's Avatar
sameold01
A neighbor of mine has a 1969 gto all factory original and I asked if I can take a reading on the positive side of the coil engine running and it was 9,4 volts. I'm not sure if someone has done some bypass wiring on this corvette but I'm reading 12.2 on the factory resistor wire black wire running. I ended up wiring in a ballast resistor and adding a 1 ohm resistor on the resistor ballast wire to the coil. Running on this 72' corvette now I'm running 9.3 volts with factory points. Thanks for all the help!
Old Dec 1, 2025 | 12:02 AM
Rebelyell's Avatar
Rebelyell
That's good thinking.
Do suggest, after a long run,and while running, feel that 1 ohm resistor for excess heat.
