What Will My Next Engine Be?
Old Nov 13, 2025 | 06:45 PM
TKX 5-SPEED C3's Avatar
TKX 5-SPEED C3
Default What Will My Next Engine Be?
I had the stock
190HP L-48 in my 1980, next was the 350 H.O.
330HP, then I upgraded to a
550HP 406. I was thinking about the
540HP 427 from Blueprint Engines OR the
670HP 434 from Skipwhiteperformance.
What say you?
Old Nov 13, 2025 | 07:02 PM
Mr E's C3's Avatar
Mr E's C3
Only if you ship me the 406 lol!
Old Nov 13, 2025 | 07:03 PM
VF-301's Avatar
VF-301
2024 C1 of the Year Finalist - Modified
I went with a 468 stroker from Ross automotive machine. 571 hp 649 tq
Old Nov 14, 2025 | 03:30 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
What are you doing with it? If you are changing it for more power then go all the way....Ive got a 580hp bbc 427. Super happy with it. All i would gain by more hp would be longer burnouts, not that there is anything wrong with that
Old Nov 14, 2025 | 03:39 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
What's a burn-out?
Answer: An OLDDDD Veteran
BUT....more seriouser....whatever you do will be fun to watch!!!!!
Old Nov 14, 2025 | 05:24 PM
TKX 5-SPEED C3
I'll sell it to you cheap!
Old Nov 14, 2025 | 08:47 PM
C3 Stroker's Avatar
C3 Stroker
Sticking with small block? How fast do you want to go? I'm biased...a need for speed thing.
Old Nov 14, 2025 | 09:20 PM
71 Vert LS1's Avatar
71 Vert LS1
I'd go LS. On a 67 Nova project I had a LS2 block sleeved by Race Engine Development out of CA. Stroked it 427 cubes. Cam was 225I/230E. Stock LS3 heads. Did 495 hp on the chassis dyno with a 4L60E. 3200 stall Yank converter. Drove like a stocker until you nailed it.
The alum LS is 200 or more lbs less than a big block?
Old Nov 14, 2025 | 09:35 PM
Bikespace's Avatar
Bikespace
If you need more power than a crate LS3, add a turbo (or two).
Old Nov 15, 2025 | 02:21 PM
68/70Vette's Avatar
68/70Vette
If I were to re-engine my 68, I'd go with a LS. The engine is favorably sized for the C3 engine bay and there's lots of parts and expertise among engine builders for this series of engines. I'd opt for the aluminum engine block versions. u
My last engine build was an all aluminum BB, 492 cubic inches, internally balanced. Calles crank and rods. Fuel Tech injection. 630 hp @ 7000 rpms.
Old Nov 15, 2025 | 10:57 PM
litevette's Avatar
litevette
Whichever you choose, I’M JELOUS! But I think I’d go with the 427 (for nostalgia & cool factor as I’m a big gasser fan and 427’s are the go to in that world) and because 540hp in these cars is waaaay more than plenty. I would think it would be better mannered all around too (if a 540hp set up could be considered as “well mannered”). Wish I was in a position to make such a choice!!!
As far as the weight savings of 200 #’s of an LS…that equates to roughly 20 ponies being freed up, which to me is not worth all of the additional effort it takes to go LS (even though there’s also a cool factor with that set up) Just my opinion though.
To What Will My Next Engine Be?
