another CODE id. question
Old Nov 23, 2025 | 02:59 PM
mbp's Avatar
mbp
Default another CODE id. question
Hello. A riend recently bought a 1970 Chevelle and is confused about what exactly engine he has. On the pad at the front passenger side the larger numbers are V04115Q, perhaps a 0 not a Q The smaller numbers are 781141238. He believes those are the correct # and letters are correct but says it's hard to see due to where it is stored. The numbers on the block at the drivers side at the back are 3814678. Any help would be greatly appreciated. Thanks in advance
Old Nov 23, 2025 | 03:23 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
This is a small block from Flint, Michigan, assembled on April 11th. There was no year indicated in this stamp. The "5" is probably an S. The code SQ is not in the Lime reference book, so it's likely not a Q and your friend needs to make sure there's not an additional letter after the "Q".
Here's the link to the Lime Book - it is sorted by code and provides usage years, size/HP, and application abbreviations:
Lime Book in PDF Format (a C2 Sticky)
@Nowhere Man is knowledgable on Chevelles to decipher the 781141238.
The site NastyZ28 has a lot of info on the block casting numbers and their date ranges of use (probably #3814671, not #3814678)
Old Nov 23, 2025 | 04:27 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
A picture would help. The other set of numbers are the vin stamp but it's incorrect as there will be a assembly plant and that will be a letter
Old Nov 23, 2025 | 06:00 PM
gbvette62's Avatar
gbvette62
Besides rechecking the numbers on the stamp pad, your friend needs to recheck the casting number too.
3814678 is the casting number for a 62-64 409/380 and 409/400 single 4 bbl intake manifold, it was never a block casting number. The casting number is likely 3914678 which is a 68 small block 302/327/350 block, but not a block ever used in 1970 Chevelles or other 70 Chevys.
Finally the suffix code, whether it is 5Q, SQ, SO or some other combination of two letters, can't be a 70 Chevrolet suffix code as all 1970 suffix codes were 3 letters, not two.
Old Nov 23, 2025 | 06:22 PM
mbp's Avatar
mbp
Thanks for the replies. I think I'll Leave it to him to fiqure it out. The car is in storage on his in-laws property and he doesn't seem to be in a hurry to look over the numbers again. Thanks again.
To another CODE id. question
