What way do your keys open your door
Old Dec 22, 2025 | 10:50 PM
forman's Avatar
forman
Default What way do your keys open your door
Friend of mines car’ the key goes in upside down to open the doors
Old Dec 22, 2025 | 10:55 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
The key should go in with the cut edge down.
Must be a "down-under" car.
Old Dec 22, 2025 | 11:00 PM
forman's Avatar
forman
Old Dec 23, 2025 | 10:57 AM
Alan 71's Avatar
Alan 71
Hello,
Looking at the 71 AIM, ( UPC1 Doors) Sheet K7, it appears that there is just one Lock Unit Item #9. No left or right.
However, the key is drawn with unusual detail showing the shape of the key and the the 'teeth' pointing down.
Regards.....
Old Dec 23, 2025 | 06:40 PM
Peterbuilt's Avatar
Peterbuilt
Default Doies this help?
Old Dec 23, 2025 | 10:49 PM
Eliredandblack's Avatar
Eliredandblack
Someone, probably named Bubba, installed the lock upside down. I wanna say that on my 73 there was no “keyway” in the fiberglass whole to ensure the lock is installed with the cuts going down. The working area around the lock is tiny and hard to get lit up, when trying to install the lock and it’s associated parts.
Old Dec 24, 2025 | 01:24 PM
Alan 71's Avatar
Alan 71
Hello,
The original lock cylinder has 4 'tabs' and the original fiberglass door skin hole as 4 'tabs'.
This post shows a way to restore the cylinder hole if the tabs are screwed up.
The original cylinder had a small gasket under it similar to the gasket under the door handle latch.
Regards....
https://www.corvetteforum.com/forums...pair-pics.html
Old Dec 28, 2025 | 09:48 PM
schnelkc's Avatar
schnelkc
Default Locks?
No help here...I've owned my vert for 26 years and I have never locked it, not even sure the door key fits
Old Dec 29, 2025 | 09:00 PM
kansas123's Avatar
kansas123
On my silly '72, one is one way and tother is the other way.
To What way do your keys open your door
