Ignition Switch
Old Feb 1, 2026 | 06:59 PM
chrome74vette's Avatar
chrome74vette
Cruising
Default Ignition Switch
I have a 74 vette, L48 350 block, has an ignition issue. I have replaced wires, plugs, cap, rotor and ensured 12v is getting to coil, even replaced coil which wasn't the problem. I believe the issue is the ignition switch but having trouble getting to it. Trying to lower the steering column to remove it but the column won't drop far enough. I loosened the column bolts in the firewall and removed the bolts from bottom of the dashboard. What am I missing?
Old Feb 1, 2026 | 08:08 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
What's the specific issue? (More details the better.)
Is this a new problem -- any changes just before the problem?
How stock is your distributor and carb?
Old Feb 1, 2026 | 09:21 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Just a thought, if your getting 12V. to the coil. How can it be the ign.switch?
Old Feb 1, 2026 | 11:28 PM
Eliredandblack's Avatar
Eliredandblack
The ignition key employs a rod ( runs down the steering column ) that moves positions on a switch. Have you adjusted or made sure that when the key is turned the rods moves the switch?
To Ignition Switch
