69 convertible Missing bracket mounting holes
Old Feb 18, 2026 | 06:49 PM
PRFKT69VET's Avatar
PRFKT69VET
Default 69 convertible Missing bracket mounting holes
This might be a silly question .........but. I've got a 69 convertible. A pic of the underside of the deck lid is attached. You can see the cable attached with the clip. The mounting hole beneath it is for the rod of the soft top release. According to the assembly manual there is suppose to be a bracket and a bumper in between those two mounting holes. As you can see, my deck lid had no mounting holes for the bracket that holds the bumper. It's the same on the other side too.This is a very early car produced in the 2nd week of production. Were these brackets and bumpers added later?
Old Feb 18, 2026 | 07:36 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
I just tried to check my late-ish 68. It’s tough because the hardtop is installed and the canvas top is in the way under it but I did not see the bumper nor do I recall seeing one before. Since your car is early it may have been added after yours was built.
Old Feb 18, 2026 | 07:37 PM
PRFKT69VET's Avatar
PRFKT69VET
Thanks for looking.
Old Feb 18, 2026 | 07:46 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Mine could also be missing. Owned since 1985.
Old Feb 19, 2026 | 04:00 PM
Alan 71's Avatar
Alan 71
Hello,
Take another look at the AIM sheet.
Look to see if there's a revision listed linked to adding those bumpers.
Maybe?
Old Feb 19, 2026 | 09:52 PM
PRFKT69VET's Avatar
PRFKT69VET
I didn't see anything that said they were added later.
Old Feb 20, 2026 | 02:57 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
I don't know when a change may have happened, but here is under the lid of my late 69. The bumpers rest on the top bow to prevent rattling.
Old Feb 22, 2026 | 03:46 PM
PRFKT69VET's Avatar
PRFKT69VET
Thanks for the pic. I'm baffled with mine. So far no answers. I'm now wondering if it's an after market deck lid.
Old Feb 26, 2026 | 10:51 AM
PRFKT69VET's Avatar
PRFKT69VET
Still looking for input on this situation. Does anyone else have a deck lid without those brackets or know of a reason why they wouldn't be there on my car? Could this possibly be an aftermarket deck lid? The picture that C69VETE sent shows his deck lid being pretty smooth and nice on the under side where mines looks fairly rough comparativly.
Old Feb 26, 2026 | 11:45 AM
Red Vert 02's Avatar
Red Vert 02
Could your car originally have been a hardtop only car and the folding top added later? Someone with a hardtop only car would have to check if the deck lid is drilled for the bumper brackets.
Old Feb 26, 2026 | 05:45 PM
C3Cliff's Avatar
C3Cliff
My car was originally hardtop only per the tank sheet. November 69 production, bought in late summer of 70 from a buddy who decided to join the military. It has the bumpers factory installed. I bought the soft top around 78 from a wrecked 69 the owner was parting out.
Old Feb 26, 2026 | 10:17 PM
PRFKT69VET's Avatar
PRFKT69VET
Well that rules that out. Plus my car came with both.
Old Mar 4, 2026 | 10:37 AM
PRFKT69VET's Avatar
PRFKT69VET
Do the bolts that attach the brackets go into factory installed nut plates or are they just into the sheet metal with self tapping screws?
Old Mar 4, 2026 | 01:52 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
The nut plates are riveted in behind the hole. This area is fiberglass so just putting a screw in there will not hold long. A brass or aluminum rivet nut with the proper size hole would be a solid option if you want to install the bumpers.
Old Mar 4, 2026 | 02:13 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
I think your best bet is to get answers from late 68 owners since you have an early 69.
My car is late May (early June completed). I will try again to crawl in there with a light to check since the hardtop is attached (and the soft top makes it hard to see the underside) but I just don’t ever recall seeing that on mine. I’ve owned it since 1985.
Old Mar 4, 2026 | 03:26 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
I just messaged a friend who is an NCRS Master Judge and kind of a 68 /69 GURU.
Now he owns a very early 68 but said his car does not have the bumpers and there is no provision for them. He added he has judged a ton of 68s and none had the bumpers.
My guess is you never had them.
Old Mar 5, 2026 | 06:50 PM
PRFKT69VET's Avatar
PRFKT69VET
Thank you so much for getting that info. My guess is also that it never had them. I have the 68/69 judging manual and it doesn't say anything about them either. The assembly manual doesn't say anything about a change either. So my guess is they just used the the left over 68 deck lids on the early ones until they ran out and then started using the ones for the 69s. Thanks again for all your help everyone.
To 69 convertible Missing bracket mounting holes
