What are these things called?
Hi guys. What are these plastic things called? There are 4 that are used to hold the rear license plate bezel in place. Any idea what size they are? Also, what is the proper fastener used to hold the bezel in place? My car had slotted screws, not Phillips. I would think Phillips would be correct?
I believe you'll find that typically there were just the nylon nuts in the top 2 holes.
I guess Chevrolet saved 8 cents on each car.
Here's a photo showing the screws typically used to secure the bezel.
Regards....
Slight difference between original (left) and what's typically available now.
Here they are at Zip https://www.zip-corvette.com/68-73-r...yThzU6mijsZRpM
