1977 engine identification
Old Mar 13, 2026 | 09:22 PM
Jdetrick's Avatar
Jdetrick
Default 1977 engine identification
I recently purchased a 77, that had been sitting in a barn, I’m trying to figure out whether the engine is original or not, it is the correct blue for a 77, but the engine identification (V0304CLA) shows as a 1970 block, with the casting number 3970010, anyone have any tips on how to find out for sure?
Old Mar 13, 2026 | 09:33 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...CLA was a 185hp/automatic L-48 engine suffix for 1977 as was the block casting of 3970010. The engine is Flint Assembly=V, March 4th=0304. Where or why do you think it's a 1970 engine? So far, what you've posted is correct & original for an L-48 1977 Corvette.
Old Mar 13, 2026 | 11:23 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking, read the stamp pad on the passengers side of the block, just at the head gasket surface right in front of the head.
the second stamped set of numbers should include the last of the vin.
Old Mar 15, 2026 | 03:36 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Correct ................ GM "CORPORATE BLUE" Started in 1977 As mentioned above, what are the rest of the numbers on the pad to the right ? ( Vin Derivative )
To 1977 engine identification
