I searched for recommended plugs, but I didn’t find what owners are using in their BB, 435hp cars.
I have seen NGK BR6ES and BR6S used, but in cross referencing it is all over the place as far as the heat range. Some say 4, 5, or 6. This is a street driven car with occasional “fun” driving.
What are you happy with? Thanks for any input.
The original equipment plugs were AC heat range 3, but heat range 5 would be better for how we drive the cars now. i used Champion heat range 13 plugs for casual driving in both a L-71 and a detuned ZL-1.
Be aware that NGK and AC Delco are opposite scales for heat ranges. With NGK, the lower the number, the hotter the plug — a BR6 is colder than a BR5. With AC Delco, the lower the number, the colder the plug — R44 is colder than R45. NGK and AC Delco cross over at heat range 5, so BPR5 is roughly equivalent to R45.
I use NGKs in both my 427 and 454. The 427 runs BPR4ES (approx. R45XLS equiv). My cars are used mostly around town and some country roads but a lot of time is spent at low speeds and not extended highway speeds. The hotter plug works well. If you are mostly at highway speeds, choose the NGK 5 or 6.
One more comment: the plug's heat range has no bearing on how hot the spark is. The heat rating is how quickly the plug itself transmits heat to the cylinder head. A colder plug can transfer heat too well and will build up deposits because the porcelain doesn't retain enough heat to burn them off while a hotter plug can retain too much heat in the plug and become a source of pre-ignition (pinging).
