Shaking / Vibration
Old Mar 24, 2026 | 03:32 PM
ALLEN007's Avatar
ALLEN007
Default Shaking / Vibration
Been dealing with a bit of shaking / vibration but really haven't messed with it in a while. Seems like it's coming from the front but not 100% sure. Anyway, while inspecting the front right area I noticed there was no space at all between the brake pad and the rotor. The pads seem to be up against the rotor. I could spin the tire but you could tell there was friction. Could this cause some shaking / vibration?
Old Mar 24, 2026 | 03:38 PM
Alan 71's Avatar
Alan 71
Hello,
The brake pads are typically up against the rotor, but with almost no pressure.
Is there any sound involved with the vibration/shaking?
Is the rotor warped?
Regards....
Old Mar 24, 2026 | 03:40 PM
Piersonpie's Avatar
Piersonpie
It’s normal for the brake pads to be very close to the rotor. Unless there’s something in the piston physically preventing it from retracing or a brake booster rod that’s too long it’s probably not the brakes.
have the wheel bearings been done recently? How old are the tires?
Old Mar 24, 2026 | 04:02 PM
SEVNT6's Avatar
SEVNT6
That's the design. The piston springs keep the pads up against the rotor with slight contact.
The last time I had a vibration it was a tire warning me of a tread separation...
Old Mar 24, 2026 | 04:23 PM
ALLEN007's Avatar
ALLEN007
Originally Posted by Alan 71
Hello,
Regards....
Every day when I first drive off the brakes squeal from that wheel until I pump them a few times. Pads are new.
Old Mar 24, 2026 | 04:29 PM
ALLEN007's Avatar
ALLEN007
Wheel bearings have not been done. But I did check by moving the tires side to side and top to bottom. No movement. Tires are new. Didn't start doing it until I got new tires. I have had the tires re-balanced at two different places to make sure it wasn't the tires. The car was only driven about once every 3 - 4 months for the last 8 years before I bought it. I think since I started driving it more the bugs are coming out to play. I'll put it in the shop in the near future. Thanks!!!
Old Mar 24, 2026 | 05:21 PM
interpon's Avatar
interpon
Road force balance tires and see how out of round they are. Problem started when tires replaced.
Old Mar 24, 2026 | 06:59 PM
ALLEN007's Avatar
ALLEN007
I had the dealer where I purchased the tires re-balance them. When that didn't help I took them to Discount Tires and had them road forced balanced. Still no luck. But they did say it took a bit to get one of them balanced. I'm tempted to take them somewhere else and have it done again. Something in me still thinks it's the tires.
Old Mar 24, 2026 | 07:46 PM
Piersonpie's Avatar
Piersonpie
What’s the date code on them? I’ve seen “new” tires that are a decade old.
Old Mar 24, 2026 | 07:48 PM
interpon's Avatar
interpon
ask for the measurement final. And replace or refund if not satisfied.
under 15 . Out of roundness seems to be a trend lately entire manufacturing.
Old Mar 24, 2026 | 10:00 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
FYI about the caliper pads slightly rubbing. Does the vibration seem worse as the tires warm up?
Also...in the early1980s GM developed caliper piston ORINGS that had a offset ridge on the O.D. The ridge pulled the pads about .015 away from the rotores to prevent wear and :grabbing".
GM accidently improved the MPG 2 miles oer gallon because the pads didn't create friction on the roiors.
I bet they trash-canned that pffset o-ring improvement.
Old Mar 25, 2026 | 05:38 AM
ALLEN007's Avatar
ALLEN007
[QUOTE=doorgunner;1609530577]FYI about the caliper pads slightly rubbing. Does the vibration seem worse as the tires warm up?
I bet they trash-canned that pffset o-ring improvement.[/QUOTE}
Because of the vibration, I probably don't drive the car enough in any one trip to get the tires warm. But the faster I go the more the vibration.
Old Mar 25, 2026 | 06:07 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Bottom line, any one of a large number of things can cause a vibration. For over 40 years I had no vibration. Then one day, I had a horrible vibration, shaking at about 70 -72 MPH. I didn't write a thread, sorry. I wrote about it extensively on the what did you do to your corvette thread over a period of close to a year. I replaced absolutely everything under my car. Nothing stopped it. New tires. Road force balance, new every everything. Drive shaft, all 6 U joints , idler arm , etc, etc, etc. Wheel bearings front and rear. Twice. Nothing helped. Did a vibration analysis to try and pin point the source. Didn't work out.
In the end. Twisted half shafts. Couldn't see it. Until I had the half shafts professionally balanced. Then it turned up.
new half shafts. Problem Solved. Everything under my car is new. Every bushing, every everything.
Old Mar 25, 2026 | 10:01 AM
Bikespace's Avatar
Bikespace
Have you tried rotating the tires, to see if the vibration moves, or changes?
I'm betting tires, too. But make sure it's not an engine issue (clutch in, or shift to neutral, and rev engine, while at speed, for example).
I'd be tempted to go back to Discount Tire, and replace the one offending tire. I'd also inspect the wheel really carefully to make sure it isn't bent.
To Shaking / Vibration
