spare tire
Old Apr 5, 2026 | 09:11 PM
loflite's Avatar
loflite
Default spare tire
Just dropped my spare tire out of my '76 for the first time. I think it is original. I bought the car with less than 50k miles 40 years ago. Would the original be a firestone? Still holds air.
Old Apr 5, 2026 | 11:07 PM
AKjeff's Avatar
AKjeff
I think the spare on my '76 is the original as well, it's never been installed that I can tell.
I was wondering if it would be worth anything to someone getting their car judged.
Between us we have half of a set, assuming they're the same model and size of tire.
Old Apr 5, 2026 | 11:44 PM
loflite's Avatar
loflite
Mine doesn't look like it was ever mounted either. The wheel looks brand new. Is yours a firestone?
Old Apr 6, 2026 | 12:10 AM
AKjeff's Avatar
AKjeff
I had to go check, it's a Goodyear Steelgard.
I have no real idea if it's original, I assumed it was because it looks unused.
Old Apr 6, 2026 | 07:32 AM
BKarol's Avatar
BKarol
Check out the date, should be 3 numbers, first two is week and last is year. Worth anything? would not expect that much of a demand but all you need is one.. I have a 78 spare that I tried to give away for free but no takers. 5th week, 1978
Old Apr 6, 2026 | 09:29 AM
SEVNT6's Avatar
SEVNT6
If it's original it would be a Firestone 500 G-70...pre numerical number..
Old Apr 6, 2026 | 12:55 PM
loflite's Avatar
loflite
I think that's what it is.
Old Apr 6, 2026 | 02:28 PM
SEVNT6's Avatar
SEVNT6
Yup, the infamous exploding 500. My right rear blew before it was 3 years old.
Don't ever consider using it...boat dock cushion only.
Old Apr 6, 2026 | 02:32 PM
loflite's Avatar
loflite
Trying to decide what to do with it. Clean it up and put it back up or get another spare tire. Fact is, if I ever get a flat, won't use the spare anyway as you have to lay on the ground to get it out, so the tire is just a place holder for the the tire support.
Old Apr 6, 2026 | 02:51 PM
SEVNT6's Avatar
SEVNT6
Years ago I weighed my spare on the bathroom scale & it was around 50 lbs. I've run without it ever since.
I have free towing with Hagerty..
Old Apr 6, 2026 | 04:58 PM
loflite's Avatar
loflite
How did you remove the carrier? Not sure how to remove the back two bolts.
Old Apr 6, 2026 | 05:16 PM
SEVNT6's Avatar
SEVNT6
I left it in...kind of hard to see.
Old Apr 6, 2026 | 05:47 PM
AKjeff's Avatar
AKjeff
They unthread. The bottom of those hangers has two flats, up at the top where they screw into the frame is a hex.
The rear one has two bolts holding it to the frame.
I pulled mine out for something, probably the exhaust, and haven't put it back yet.
Old Apr 6, 2026 | 08:32 PM
loflite's Avatar
loflite
Thanks for all the info!
Old Apr 6, 2026 | 10:19 PM
Mod75's Avatar
Mod75
2024 C3 of the Year Winner - Modified
My original 500 form my 75, kept this one as a spare for some 35 years but never did use it. Tire was hard as a rock when replaced.
To spare tire
