E15 concerns with older vettes
Old Apr 12, 2026 | 09:13 PM
Bigmoo's Avatar
Bigmoo
Default E15 concerns with older vettes
Im concerned about new E15 regulations. I have stock 86 and 77 vettes. Im not sure if there will be no choice about it in Ohio yet. What can I do if I'm forced to use it? Is there any additives I can use to reduce moisture issues related to E15? There must be something I can do to protect these cars?
Old Apr 12, 2026 | 09:21 PM
Piersonpie's Avatar
Piersonpie
The best thing you can do with ethanol gas in these cars is burn it instead of letting it sit around.
Since your ‘77 is stock it should have a Quadrajet. The accelerator pumps are known for not liking modern ethanol fuel blends. Here’s a link to one of the best replacements on the market. That’s not necessarily ethanol “proof,” but should resist swelling and coming apart better than anything else. Other than that, use non ethanol on your last fill up before storing the car for long periods of time.
Old Apr 12, 2026 | 09:27 PM
SEVNT6's Avatar
SEVNT6
I found this the other day...
https://www.chevyhardcore.com/tech-s...re-filling-up/
Old Apr 13, 2026 | 07:56 AM
stingr69's Avatar
stingr69
I hope we only get the OPTION to use E15. If we get the option to keep running E10, I would just continue to run that.
We have some local stations selling no-ethanol gas but it is usually low octane.
Old Apr 13, 2026 | 09:23 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I hear ya'..My two problems are/were:
1. E15 swelling the inside duameter of the rubber hose from the tank to the the steel line on the chassis. I replaced that hose with high pressure hose designed for late model cars that have fuel injection per Forum Members.
2. ANYTTHING made of rubber or near-rubber inside the carB began dissolving. I'll use your advice in this thread to buy rebuld parts for the carb that will last longer.
Old Apr 13, 2026 | 04:42 PM
71 Vert LS1's Avatar
71 Vert LS1
The 91 octane around here in MN is non-ox. Costs about 50-60 cents a gallon more. I run it in all my hot rods and small engines. Never had a problem letting them from sit from Nov-Apr.
I guess it depends on how many miles you put on the car the 91 octane is cost wise.
Old Apr 14, 2026 | 05:51 AM
bashcraft's Avatar
bashcraft
Are you saying that E10 won't be available at some point?
Old Apr 14, 2026 | 11:42 AM
Mr E's C3's Avatar
Mr E's C3
If you live in a US state that has Maverick stations they sell "clear gas" ethanol free with octane 88 or 91. I use it in my 76 modified 350 without issue.
Other that there are addatives available to combat negative ethanol effects per google.
Old Apr 14, 2026 | 02:36 PM
Bikespace's Avatar
Bikespace
My quick read is that E15 will be more available (I can already get it at some Sheetz near me), but that E10 isn't going away. Nor is ethanol-free, if you can find it near you.
Other than chainsaws and lawn tractors, I only have one car left that prefers ethanol-free gas, so that's what she gets. Everything else already has an LS, or is in the process of being swapped. If you really want to future-proof your car, you convert an LS to run on E85 pretty easily. There's lots of that available near me, and unless Louisiana blockades the Mississippi River, that's unlikely to change.
Old Apr 14, 2026 | 06:24 PM
Fly skids up!'s Avatar
Fly skids up!
I'm going to start using ethanol-free gas even though I have to go out of my way to get it. Here's a website that lists gas stations with ethanol free gas: https://www.pure-gas.org/
Old Apr 16, 2026 | 04:38 PM
vairxpert's Avatar
vairxpert
Every car and motorcycle forum I belong to is in a panic over this.
E15 (88) has been out for several years in over 30 states at larger gas stations that offer 87,89,91,92,93,E85,Kerosene,Diesel and sometimes 100+ racing fuel.
E15 has only been sold during the winter months. It's on it's own pump with a blue nozzle, usually next to the E85 pump with a yellow nozzle.
The Department of Energy has issued a waiver allowing E15 to be sold during the summer months...that's it. If someone accidentally puts E15 in their car, it's because they're color blind and/or can't read.
This is as bad as people acting like 10% ethanol is a new thing because they read about it on the internet. Not aware their grandparents were using it in their new Ford Pinto while listening to the latest Bee Gees 8 Track.
I took this photo about a week ago. That blue nozzle has been there for many years.
From the EPA website:
The emergency fuel waiver will temporarily waive the summer low volatility requirements and blending limitations for gasoline to provide additional flexibility to the fuel marketplace. This will increase fuel supply and provide a variety of gasoline fuel blends to choose from without changing environmental protections already in place. E15 is currently offered at over 3,000 gas stations nationwide, where it serves as a more affordable choice for Americans.
To E15 concerns with older vettes
