C3 dash cover installation questions
Old Apr 19, 2026 | 04:04 PM
jr73's Avatar
jr73
Default C3 dash cover installation questions
I bought a dash cover for my 73 from Zip.
it seems kind of rigid like it will fight adhesive when I try to bond it. Anyone here do this task? Any tips?
pix to follow.
Old Apr 19, 2026 | 05:33 PM
Alan 71's Avatar
Alan 71
Hello,
Something like this?
Regards.....
https://www.corvetteforum.com/forums...pad-cover.html
Old Apr 19, 2026 | 06:16 PM
jr73's Avatar
jr73
Alan thanks for your reply. I read thru the thread and it sounds like mine is a “cap” because it is rigid. I have it on my workbench and when I press it on the old dash on one end the opposite end pops off then I go to the other end and the opposite pops out which makes me wonder if that silicone adhesive they sent will hold. I do know from experience on other applications that silicone is very strong.
Old Apr 19, 2026 | 07:25 PM
Alan 71's Avatar
Alan 71
Hello,
When reading all the posts it seems the words cap, skin, pad seems be used interchangeably.
In my dictionary they are 3 different things .....so???
Regards....
Old Apr 19, 2026 | 08:38 PM
jr73's Avatar
jr73
after studying these for a while it just seems like the “cap” just doesn’t have enough clearance to lay on there right.
Old Apr 19, 2026 | 08:42 PM
jr73's Avatar
jr73
So I started to chip away the old vinyl on the front and it seems to help so I’m gonna remove some more until it fits good.
Old Apr 20, 2026 | 07:00 AM
sleepchamber's Avatar
sleepchamber
Let us know how it goes
Old Apr 21, 2026 | 09:16 PM
jr73's Avatar
jr73
Part of the old dash where the defroster vent is will be visible through the windshield so I’m gonna cover that small area with black vinyl.
Old Apr 22, 2026 | 03:40 AM
Eliredandblack's Avatar
Eliredandblack
My OEM Dash Cover (or whatever it’s called) has a plastic insert for the defroster vent. You are missing that part, look in a vendor catalog and you will see what it looks like. They shouldn’t be very expensive. A hair dryer may help to adjust the new cap/cover for a better fit. I used a hair dryer to warm up my OEM cover, so it could be removed when I replace the radio speakers.
Old Apr 22, 2026 | 09:13 PM
litevette's Avatar
litevette
I have that vent if you want it for the cost of shipping. Rather than try to vinyl that tan showing, I would get some black interior dye (spray can). You can mask your new pad and go to town on it. Or simply spray it before applying the new pad/cover.
Adhesive wise,… I’d get a tube of construction adhesive, apply liberally (but stay away from the edges. I’d then pop one end on, secure it with clamps (not too tight and with rags or foam project paper under the pads/feet to prevent scratching your new cap and to spread the load of the clamps) then work my way to the other end, clamping everything as I went.
Old Apr 22, 2026 | 09:15 PM
jr73's Avatar
jr73
I have it but it won’t cover that little strip of saddle colored dash.
Old Apr 22, 2026 | 09:49 PM
jr73's Avatar
jr73
thanks anyway for the offer. Also those are good tips there.
Old Apr 22, 2026 | 11:26 PM
litevette's Avatar
litevette
Certainly brother! Good luck with it. I’m sure you’ll get it licked in high fashion!
Old Apr 23, 2026 | 03:08 PM
jr73's Avatar
jr73
So I have the old Saddle colored one to demonstrate and some of that old dash would still show. I did glue some black vinyl there. The new black one was ordered last week. This new dash cap is not without its faults but was more affordable than a new dash.
At least from the driver’s viewpoint it covers nicely.
Old Apr 27, 2026 | 09:05 PM
jr73's Avatar
jr73
So trimming away vinyl and foam until it sat nicely helped it lay on there much better than when I first set it on there. I had to buy more RTV than what was supplied by the vendor. The one small tube that came with it from supplier that Zip uses wasn’t gonna cut it.
Old Apr 27, 2026 | 09:37 PM
jr73's Avatar
jr73
One thing I would have arranged ahead of time is some spacers or wood blocking to place under the old dash to support it for after the RTV is on and the cover is placed on it because when I put the small sandbags on it got kind of funky. So I scrambled to get some in there. I used Walmart bags for sandbags. Also a few spring clamps in there.
To C3 dash cover installation questions
