Help about wheels and tires
I’ve gone arround the forum reading a lot of threads, but I still don’t have things clear about a matter related with wheels, and I hope you all may help me.
I own a 1973 C3 in Spain, and I want to replace rear wheels and tires for ones bigger and nicer. The problem in Europe is that the wide of wheels and tires have the limit of the fender flares. I mean, that they can’t go beyond fender flares. Not even half an inche.
I love that tires get just to the limit of the flare, but, as I said, they can’t go beyond it. I want to fit 275/60 R15 rear tires, that, as I have watched at many C3 Corvettes here and at C3 Facebook group, look just great. And, as I have watched in most pics, they get just to the limit of flares.
And about wheels, as I watched at Ecklers, there are two Vision brand ones wich I like very much. More even than Cragars. I have 2 possibilities about wheels:
1- 15x10, -25 mm offset, and 4.52 inches backspace.
2- 15x10, 0 mm offset, and 5.50 inches backspace.
The ones I like the most, as I love rear wheels to look very “deep”, are the ones at number one with 4.52 backspace. But, what do you think about it? Ones at number one together to 275/60 R15 tires, would protrude from fender flares? If so, how many inches would go beyond flares? And no issues should be done about brakes or rubbing at any place?
I hope you may help me!! Thanks in advance!!
I will ask in a diferent way: Anybody is running 275/60 R15 tires on 15x10 wheels with 4.52" backspace? If so, do they go beyond flares? And any rubbing at any place?
Unfortunately for you, the rear tread stuck out 1” beyond the top of the fender, with the sidewall protruding another ~1”.
In the second photo, I had modified the fenders to move the lip out to cover the tread but the sidewall still does protrude about an inch.
Bone stock. No mods.
Rear fenders move outward 1”.
But it would protude 1 inche. And, if backspace was lower, it would potude even more, I guess.
Maybe the solution for me would be to fit some flare extensions like in the pic attached. Or run smaller wheels.
