T-Top Stickey
Old Apr 27, 2026 | 01:08 PM
Bob3700's Avatar
Bob3700
Default T-Top Stickey
I was noticing that the interior surface of the T-Tops on my 70 coupe have become "sticky" to the touch. What can I use to clean them and return them to their "non-sticky" condition.
Bob
Old Apr 27, 2026 | 01:15 PM
Greezy's Avatar
Greezy
I have not had this problem yet. I'm here to learn the solution should it occur for me.
Old Apr 27, 2026 | 02:30 PM
SEVNT6's Avatar
SEVNT6
One problem I've never had. I'd try this..
https://armorall.com/product/cleaning-wipes/
Old Apr 27, 2026 | 03:11 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Usually read about sticky plastic having to do with the steering wheel.
Plug this phrase into a google search:
site:corvetteforum.com "sticky steering wheel"
I used denatured alcohol and/or VM&P naphtha (I don't recall which - maybe both) to remove it from my steering wheel. It took a few wipe-downs, but did work in the end. Kerosene would work similarly. Test a small area to make sure the headliners do not have a dye coating before doing the whole job. Acetone or lacquer thinner may damage the vinyl and its patterning.
Old Apr 27, 2026 | 06:33 PM
Bob3700's Avatar
Bob3700
The car is original ( I have owned since 1974) so no added vinyl paint to worry about.
Steering wheel is fine, just noticed the “ sticky” surface when I drove it last night.
The. Car is a garage Queen so not regularly exposed to hot sun n high temps. Has to be just an age issue as the complete interior is original to the car (43,000 mls).
Old Apr 27, 2026 | 06:50 PM
Ralphthehoer's Avatar
Ralphthehoer
Bob
i use blue dawn dish soap , a few drops on a damp magic eraser , scrub what your cleaning with it and then a clean dry micro fiber towel to wipe it off.
Old Apr 28, 2026 | 06:29 AM
sleepchamber's Avatar
sleepchamber
I used saddle soap with great results on all of the interior pieces of my 72. Took a little elbow grease but worked fantastic and didnt harm the material at all. Nothing else i tried worked.
Old Apr 28, 2026 | 01:47 PM
sunflower 1972's Avatar
sunflower 1972
This stuff works great on pretty much everything.
To T-Top Stickey
