engine run-on
Old Jan 27, 2005 | 08:32 AM
greyghost79's Avatar
greyghost79
just be sure you put it in correctly. diodes allow current to flow only one way. if you put in in backwards it won't do you any good.
Old Jan 27, 2005 | 09:19 AM
Matt Gruber's Avatar
Matt Gruber
Originally Posted by isosceles
Did that work Matt? MSD suggests putting it inline on the alternator brown wire.
when i switched OFF it ran fine radio shack diodes 3/$1.29 fixed it.
i don't have MSD, but for $1.29, TRY IT!
Old Jan 27, 2005 | 09:37 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
What distributor and how much end play do you have?
Old Jan 27, 2005 | 02:41 PM
i885744's Avatar
i885744
I think the msd instructions say not to use the ballast resistor if you are running the 6al Box. I have a 6al and a blaster II coil with no resistor and no problems. Timing sounds dead on. Make sure your valves are properly adjusted. Make sure your idle air is properly adjusted. Make sure your choke is working properly.
