engine run-on
Old Jan 26, 2005 | 02:40 PM
isosceles's Avatar
isosceles
Default engine run-on
How do ya stop it? I use 93 octane gas. Initial timing is at 14 BTDC. Total mechanical advace = 36, no vacuum advance. I have an MSD 6AL box and installed the ballast resistor as per their instructions. The motor idles near 1000 RPM in neutral/park and 650 in drive, I can't go any lower.
Turning it off in gear seems to work, but would rather not have to do that. MSD suggested trying to turn off the motor with headlamps on (draw current) as a test to see if an in-line diode is needed, but it still runs on when I do this.
The L48 started running on a bit about a month before I yanked it out.
Any thoughts?
Thanks,
Old Jan 26, 2005 | 03:00 PM
CGGorman's Avatar
CGGorman
I have the same problem. MSD Digital 6 with diode. Manual tranny.
danboback's Avatar
danboback
mine has the same problem and I haven't figured this out, so if anyone has any ideas that would be cool!
Old Jan 26, 2005 | 03:14 PM
Twin_Turbo's Avatar
Twin_Turbo
could be a lot of things, too much advance, too low octane gas, carbon deposits in comb. chamber, too hot spark plugs, sharp edges in combustion chamber, lean mixture, rich mixture (carbon deposits),
Old Jan 26, 2005 | 03:22 PM
commando57's Avatar
commando57
Default Resistor?
You would want full voltage wouldn't you?
Matt Gruber's Avatar
Matt Gruber
i always shut mine off in gear, i wouldn't consider neutral. no run-on ever
But, i always joke that if i sold it, a new buyer couldn't drive it without written instructions and 3 days of training
Old Jan 26, 2005 | 03:24 PM
LemansBlue68's Avatar
LemansBlue68
Is it a dieseling type of run-on? If so, you'll find that blipping the throttle after shut-down will get it to stop. This is one of the reasons that solenoids were fitted to carbs in the early '70's. Not only did they control idle speed but would pop the throttle open slightly to avoid after run at shut down. Using higher octane fuel should help too, although that's just a band-aid. Could also be due to carbon deposits/hot spots.
Old Jan 26, 2005 | 03:25 PM
JRODDVETTE's Avatar
JRODDVETTE
turn the idle down.
Old Jan 26, 2005 | 03:29 PM
Matt Gruber
but, let's say i had a tough customer who demanded this arcane feature.
I'd install an idle stop solinoid hooked to the neutral safety switch. wired to boost idle speed in gear and reduce it to 600 in neutral. And he'd pay plenty for it
Old Jan 26, 2005 | 04:26 PM
djcwardog's Avatar
djcwardog
Thoughts - Drop initial timing a bit (maybe to 10 degrees or less) and see if problem goes away. You can also put something in the fuel to clean up the chambers a bit... You also want to be sure the throttle blades are as closed as possible, lower idle RPM and check the idle mixture settings.
Old Jan 26, 2005 | 04:28 PM
Twin_Turbo's Avatar
Twin_Turbo
water through the carb will clean up the chambers and the pistons, ATF also...don't flood the engine in it and do it with the throttle opened, the ATF will make some nice smoke also, perfect to annoy the neighbours
Old Jan 26, 2005 | 04:31 PM
JMoney454's Avatar
JMoney454
Marvel Mystery Oil is supposed to be good for cleaning the combustion chambers as well.
Old Jan 26, 2005 | 05:10 PM
BigBlockk's Avatar
BigBlockk
Any thoughts?
Thanks,
Are you sure the initial timing is right? Have you verified that the ring on the damper hasn't moved? A quick test would be to slowly advance the timing by ear while readjusting the idle speed on the carburetor. If you get to a place where the engine will idle at something lower than 1000rpm AND shut down clean I believe you have found the problem.
Also, a slight vacuum leak will force you to idle the engine higher to prevent stalling. You may want to look for old cracked hoses.
Hope this helps.
BigBlockk
Later.....
Old Jan 26, 2005 | 06:58 PM
greyghost79's Avatar
greyghost79
does it continue to run on now that you've un-installed the MSD ignition??? if so, sounds like dieseling after shutoff (pre-ignition). i had a 78 camaro (when they were new) with a 350 and quadrajet. it started doing this REAL BAD after a few years. even the Chevy dealers mechanics could never get it stopped. probably a bad dose of carbon build up in the engine from carb running rich for a long time. that raises compression dramatically and can cause this problem. try some of the suggested home remedies like Marvel Mystery Oil, etc. if that doesn't work and engine timing is correct and ignition system is in good working order then your probably looking at removing the heads at the very least and de-carbonizing the pistons.
Old Jan 26, 2005 | 08:28 PM
isosceles's Avatar
isosceles
along with the noise
yes, this is the same as dieseling. I still have the MSD box hooked up.
Matt; that device is exactly what I'm looking for and that customer would be my wife for when she drives my car.
Old Jan 26, 2005 | 09:01 PM
EDDIEJ82's Avatar
EDDIEJ82
Put the diode inline with the alternator. Even a small amount of residual energy bleeding back thru your sys from the voltometer is all the MSD box needs to amplify it enough to fire the plugs.
Old Jan 26, 2005 | 09:30 PM
greyghost79
MSD says this can be a problem with some vehicles. fortunately i haven't had that problem with mine........ yet. put the diode in and see what happens.
To engine run-on
Old Jan 27, 2005 | 05:59 AM
Matt Gruber
years ago, i did put a diode in my 61.
Old Jan 27, 2005 | 07:53 AM
isosceles's Avatar
isosceles
Did that work Matt? MSD suggests putting it inline on the alternator brown wire.
Old Jan 27, 2005 | 08:02 AM
superdad60's Avatar
superdad60
How about a can of octane booster each fill up?
Mine never knocked again!
Of course an extra $5 each fill in a daily driver would suck
