Quadrabog Question
Old Jan 26, 2005 | 03:19 PM
Darrell's 68's Avatar
Darrell's 68
Default Quadrabog Question
I bought a good used quadrajet for my 68. Everything seems to work fine except the secondary air flaps. When I put my right foot down far enough the secondaries open up but it is not very smooth at all. What is the proper way to adjust them?
Old Jan 26, 2005 | 03:30 PM
Fevre's Avatar
Fevre
E-mail Lars, he is the forum guru for carbs and beer (among other things) and all around good guy, sure he has a tech paper written on the subject he will e-mail ya.
lars.grimsrud@lmco.com
Old Jan 26, 2005 | 03:37 PM
lars's Avatar
lars
First, make sure your choke pulloff is functional and operable: It should hold a vacuum and fully retract when the engine is running or when you suck on it. If not, replace it. Also, make sure the carb has the secondary airvalve rod hooked up between the pulloff and the lever on the airhorn - I see many carbs with the rod missing.
Next, set your secondary airvalve spring windup: There is a small allen-head screw on the bottom surface of the airhorn, right underneath the airvalve lever. Loosen this screw about 1/2 turn to unlock the windup screw: the windup screw is the slotted head screw that's located right by the secondary airvalve shaft and lever. Using a mirror underneath the airhorn, unwind the airvalve spring until you see the spring lose contact with the airhorn shaft tang/pin. Bring the spring into contact with the pin and wind it up 3/4 turn with the slotted screw. Hold it at 3/4 and snug up the allen screw on the bottom surface to lock the windup in place.
Old Jan 26, 2005 | 04:09 PM
Les's Avatar
Les
You know, I read this without looking at who wrote it & thought "Wow, this guy really sounds like he knows what he's talking about. Maybe we have another guy like Lars on the forum." Then I saw who it was & it all made sense.
Old Jan 26, 2005 | 09:01 PM
74FLCONV's Avatar
74FLCONV
Lars has forgotten more stuff about Q-Jets than we'll ever know.
D. Ocean
Miami, FLA
Old Jan 26, 2005 | 09:14 PM
comp's Avatar
comp
D. Ocean
Miami, FLA
To Quadrabog Question
