Vortec Intake Torque?
Old Jan 26, 2005 | 09:37 PM
jdmick's Avatar
jdmick
Default Vortec Intake Torque?
I'm putting the vortec intake on my 350 HO engine and don't know the torque specs and tightening pattern. My old Haynes doesn't have it. I assume you work from the inside out? Also should I use sealer on the gasket? Looks like a rubber type Felpro. Thanks. John
Old Jan 26, 2005 | 09:44 PM
Nate '69's Avatar
Nate '69
Hey, I'm in the process of doing this too. The torque on the intake is 11ftlbs and no more. It's low torque and you should not use any sealant - but you do need sealant on the front and rear.
I tightened from the inside out in a criss cross pattern.
Good Luck!
Old Jan 26, 2005 | 10:22 PM
jdmick's Avatar
jdmick
That sure is a lot lower than the old 30 ft.lbs. Good thing I asked. Better use loctite or the bolts will fall out. Thanks!
Old Jan 27, 2005 | 12:57 AM
Jclgodale3's Avatar
Jclgodale3
I think Edelbrock suggest 25 ftlbs. Also, most rebuild sites I've seen suggest the gasket sealer on both sides of the gasket...jmo
Old Jan 27, 2005 | 08:12 PM
Sarge81's Avatar
Sarge81
11 ft.lbs w/ locktite. Or the bolts will back out. I have a 350 HO with a Vortec Perf. manifold on my '81. Are you using GM intake gaskets or the ones supplied by Edebrock?
Darryl
To Vortec Intake Torque?
