Engine Experts
Old Jan 27, 2005 | 04:36 PM
redc3's Avatar
redc3
Default Engine Experts
ok guys, need some help. im still building this 383, its painted and i got the headers on just for looks. but my question is, i seem to remember something about drilling a hole behind the cam gear and above the cam for extra oiling and longer life. where do i drill this hole??? certainly not in the oil galley plug. above this or below? and what size? im sure its tiny. any help is greatly appreciated.
Old Jan 27, 2005 | 04:44 PM
Twin_Turbo's Avatar
Twin_Turbo
You can either drill it in the thrust surface or drill a hole in the center gallery plug and install that one (a screw in plug, not the hammer in stock types, you must tap the block to use those)
Drill a hole about .030" in diameter.
Old Jan 27, 2005 | 04:52 PM
marshrat99's Avatar
marshrat99
Old Jan 27, 2005 | 04:55 PM
fauxrs's Avatar
fauxrs
The oil gallery that runs down the center of the lifter valley terminates front and rear in the timing chain and flywheel valleys respectively. I drill a .03125 (thats like 1/32" ) hole in the center of the pipe plug at the front to lubricate the timing chain and torrington bearing.
The pipe plug is fine...if you are still using a press in plug - tap it out and use a pipe plug....in fact the pipe plug is a much better location than drilling the block. IMO - YMMV
Old Jan 27, 2005 | 04:59 PM
comp's Avatar
comp
good info
Old Jan 27, 2005 | 05:46 PM
redc3's Avatar
redc3
thanks again guys. now i got more stuff to buy for this thing
Old Jan 27, 2005 | 08:24 PM
carl a's Avatar
carl a
gotta love that!!!
To Engine Experts
