TH200R4 guys - need help!!
Old Jan 27, 2005 | 11:53 PM
comp's Avatar
comp
cut it .....
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by isosceles
one problem is that he has a fixed tranny crossmember. My crossmember is obviously not stock, but many forum members have used their stock crossmembers on the 200r4's.
I even used the stock 4-speed crossmember (welded in)
Old Jan 27, 2005 | 11:56 PM
comp's Avatar
comp
good luck ,but you need room when you hit the Loud pedal
Old Jan 28, 2005 | 12:00 AM
Schmucker's Avatar
Schmucker
Why not just screw a 90 degree elbow fitting into the transmission fitting?
Old Jan 28, 2005 | 12:05 AM
GrandSportC3
There's no way to get the fitting into the port... There would be enough space with the fitting in place.. but I just can't get the fitting in... The fitting is about 1 inch long, but I only got less than 3/4 inch of space..
Old Jan 28, 2005 | 07:45 AM
GrandSportC3
Any more input?
Otherwise, I'll cut the tunnel tonight...
Old Jan 28, 2005 | 08:06 AM
comp's Avatar
comp
Any more input?
your best bet
Old Jan 28, 2005 | 08:09 AM
mrvette's Avatar
mrvette
Gs, on my '72 700 here, I have holes in the pass side just for those cooling lines, and sheet aluminum....not to mention widening the tunnel to clear....so yes, i'ts a cut and make do situation....apparently the exact sizes of these bodies on these old sharks varied all over the place, tons of posts about alignemnt of body on frame, relative placement of glass in the floors, clearancing trannies, driveshafts....methinks the production tollerances in the floorboards were plus/minus an inch or so...
GENE
Old Jan 28, 2005 | 08:12 AM
GrandSportC3
Looks like a cut would be my best bet then. It also gives me easier access to all the other stuff there..
Old Jan 28, 2005 | 08:47 AM
comp's Avatar
comp
Race Car
