TH200R4 guys - need help!!
Old Jan 27, 2005 | 11:02 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default TH200R4 guys - need help!!
Could anyone post or e-mail me a pic of where the cooling lines attach to the tranny?
I'm having trouble finding a fitting that's small enough to attach it to the lower cooling line port. The port is only about 3/4 inch from the tunnel..
I was already thinking in cutting the tunnel so that I can easier attach a fitting to connect the hose and then cover the hole with sheet aluminum..
Old Jan 27, 2005 | 11:26 PM
comp's Avatar
comp
can you lower the tail-shaft to install and raise it back up ????
Old Jan 27, 2005 | 11:27 PM
isosceles's Avatar
isosceles
Heya Olivier!
You're PM box is full!
Check these out: one of mine looks a little bent up, but the pressures and temps are fine so it must not be restricting flow. they don't show what happens as the lines run toward the front. Mine run right next to the oil pan.
I'm thinking of getting one of those permacool coolers with a fan on it so I can mount it back there anyhow and not have to run long pipes.
http://home.swfla.rr.com/woot/images/pics/
Old Jan 27, 2005 | 11:28 PM
GrandSportC3
The transmission mount is already in place.. That would be a pita to do...
Old Jan 27, 2005 | 11:29 PM
comp's Avatar
comp
crow's foot
Old Jan 27, 2005 | 11:31 PM
GrandSportC3
Originally Posted by isosceles
Heya Olivier!
Hmmm.. I wonder why you have so much more space than I have
Old Jan 27, 2005 | 11:34 PM
isosceles's Avatar
isosceles
I don't know if that is a year difference or man/auto difference. Anyone out there with a 68 auto?
Old Jan 27, 2005 | 11:36 PM
comp's Avatar
comp
everthing sitting lower ???? That line looks BAD
Old Jan 27, 2005 | 11:43 PM
GrandSportC3
Here's a pic of the problem... The lower port is 1/2 to 3/4 inch from the tunnel....
Old Jan 27, 2005 | 11:44 PM
isosceles's Avatar
isosceles
I agree. Didn't really notice how bad until I looked at the pic. I took that shot not even looking through the veiw finder. On jackstands it's hard to see up in there physically.
I'll put a new pipe on it when I decide where to mount the tranny cooler. If not, I might at least put a union on it and replace the end. I don't think I can replace the whole line with the motor and tranny in the car, but I could be wrong.
Old Jan 27, 2005 | 11:46 PM
isosceles's Avatar
isosceles
Oliver,
Any chance of taking that one out and installing a 90 degree fitting? Is there room to even do THAT?
Old Jan 27, 2005 | 11:47 PM
GrandSportC3
Mark, were those pics taken with the tranny in place or during the install.. It appears as if your tranny is tilted forward...
comp's Avatar
comp
GS crow's foot , lower it and/or a 15deg. fitting
Old Jan 27, 2005 | 11:48 PM
GrandSportC3
Can't lower it... I could only lower the rear but not the front. I'd have to remove the engine to lower it..
Old Jan 27, 2005 | 11:49 PM
isosceles's Avatar
isosceles
installed. I did took them while I was under the car running the fuel pump wiring.
Old Jan 27, 2005 | 11:50 PM
comp's Avatar
comp
the tail is what i ment,,, when the engine move's (and that baby will) is it going to hit ?????? cutting may be best
Old Jan 27, 2005 | 11:51 PM
isosceles's Avatar
isosceles
one problem is that he has a fixed tranny crossmember. My crossmember is obviously not stock, but many forum members have used their stock crossmembers on the 200r4's.
To TH200R4 guys - need help!!
GrandSportC3
Very strange.. Your tranny seems to sit 2 inches lower than mine
Old Jan 27, 2005 | 11:52 PM
comp's Avatar
comp
damm
GrandSportC3
That's what I'll probably end up doing.. I'll only cut a 2 x 2" section and cover it with a sheet aluminum piece that I'm going to rivet or screw on...
Luckily the interior isn't in the car.. so that shouldn't be a problem...
