how many cfm?
So far I have a new 454 HO crate engine with an LS6 intake manifold. I was going to use the old quadrajet but I need a square bore, and I might as well get a better carb anyway.
My question is which carb? I know this has been asked alot and I have read a bunch of the old posts. I had been thinking about a 800 or 750 Edelbrock performer. After reading a few posts I am not sure.
Things to consider: I am not sure if any carbs are too tall butt I want to keep my original 71 BB hood, thats why I got the LS6 intake. This is a street car. Not a daily driver but almost. Fast is fun. Gas prices are high. I know a few of those are almost directly contradictory, still they are considerations.
THANX
TED
THANX
TED
THANX
TED
I run a Holley 850 that's tuned with an O2 sensor. It runs great. Even on a mild 454, don't run less than an 800 cfm in a Holley or BG.
THANX
TED
And from my understanding, the LS6 intake is the only manifold ever made that will clear the hood on a BB with square ports. It has a low profile. It came stock in a handful of 71 LS6s I think. However, I am no expert and my knowledge comes from reading other's posts.
- Real life, hands on tuning of the carbs referenced in this thread
- Real life, hands on evaluations "" ""
- Real life, hands on comparisons - side by side and substitution
I hope that answers your question. I hung around with guys like Lars in the 60's and early 70's - wizards!! I learned a lot from them, and I have done a lot with a lot of cars over the years, but when you got real serious issues, you gotta get in touch with the wizard. In this house, that would be Lars.
Your engine combo will run great with either a 750 or an 850 on it. My personal preference would be an 850. People with Over-Carbo-Phobia will tell you 750 (or 390, or something...)
Here are some facts from recent personal experience - I've tuned and installed literally hundreds of carbs, so I'm not pulling this out my rear:
- Pulled a well-tuned Speed Demon 750 (mechanical) off of a stock 427 and installed a Speed Demon 850 (mechanical). Results: Noticeable improvement in off-idle feel, throttle response and top-end power.
- Installed the 750 Speed Demon (which flows a bit more than 750) from the 427 on a stock 350 after removing a stock 750 Q-Jet. Results: Significant improvement in throttle feel, low-end torque, and WOT power.
- Pulled a 650 Speed Demon off of a built 355 and installed a 750 Speed Demon. Results: Massive improvement in power and throttle feel throughout the rpm range.
- Pulled a 650 Edelbrock Performer carb off of a stock 350 and installed the 650 Speed Demon (which flows more than 650). Results: So much of an improvement in throttle response and power that even a girl was able to tell the difference.
- Pulled an 850 Holley HP (mechanical) off of a small block 406 and installed a 1050 Dominator. Results: Reduced 1/4-mile times by .2 second.
Question I get asked a lot: Have you ever installed a carb that was too big, resulting in off-idle and low-rpm problems. Answer: No. I've never been able to get a "too big" carb to perform badly or poorly at any rpm. Every case of problems that I have seen associated with a carb that's "too big" (stumbles, rich mixture, poor torque) have been tuning problems with the engine not associated with the size of the carb, and the problems have been fixed by correctly tuning the carb & ignition - without changing the size of the carb.
If it were me, I'd go for an 850 on a big block. No question about it. Keep the rpm up and keep the engine in its power range before you hammer it. You'll have a great time. The 750 will run well, and is a safe bet. But a well set up 850 will take it...
Here's a 1050 cfm carb on one of our small blocks. Street driven and runs mid-10's:
http://forums.corvetteforum.com/pho...php?photo=29692
THANX
TED
