Project update...
Old Jan 29, 2005 | 01:57 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Project update...
Did a few things on the Vette after work today.. well - actually yesterday
Installed the electrical fuel pump and water pump (still need to wire it), the drivers side interior, seat, racing harness and also a remote fuel pressure gauge. I also cut a hole into the tunnel at the drivers side to be able to gain better access to the transmission cooling ports...
Here are pics of the harness and the hole...
Old Jan 29, 2005 | 01:59 AM
79VetteMike's Avatar
79VetteMike
You mean this wasn't a post about Merlin? JUST KIDDING!!Nice work Oliver.
Old Jan 29, 2005 | 02:48 AM
djcwardog's Avatar
djcwardog
Default I like it!
I may have missed early posts, so can you tell me the concept behind this project? A full-on race car in the spirit of the C2 Grand Sports? Keep up the good work - and photos for the rest of us!
Old Jan 29, 2005 | 02:58 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Did you chew that hole in the tunnel? lol just messing. Gonna be a hell of a fun car when you are done!
David
Old Jan 29, 2005 | 05:53 AM
Twin_Turbo's Avatar
Twin_Turbo
for gods sake man, spray some paint on that floor...it makes the car look like an old beater, I like modifications and it looks like you are doing a nice job but I can't stand undetailed and messy looking stuff...or is this a rush job to make the 1st race and then a thorough detailing is done afterwards?
Old Jan 29, 2005 | 08:10 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Yeah! And spray that roll cage too.
Old Jan 29, 2005 | 08:18 AM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
You gonna be done in time for CI, Oliver. I'll never forget hearing you stand on it from every stop on the OMGWAGBK last year. And hearing you say " I have only 1/8th of a tank left" when we pulled into that school parking lot after the run!
Aflac's Avatar
Aflac
St. Jude Donor '09
You gonna be done in time for CI, Oliver? I'll never forget hearing you stand on it from every stop on the OMGWAGBK last year. And hearing you say " I have only 1/8th of a tank left" when we pulled into that school parking lot after the run!
Old Jan 29, 2005 | 10:01 AM
GrandSportC3
It'll be a Pro-Street type of car.... It'll be driven on the street on a regular basis, but mostly around town.. The car will probably see more track time than street time...
Old Jan 29, 2005 | 10:03 AM
GrandSportC3
David
I usually use a Dremel cutting bit (looke like a drill, but cuts). That cuts through fiberglass like butter...
Old Jan 29, 2005 | 10:05 AM
GrandSportC3
Why would I paint the floor? It'll be covered by carpet when I'm done...
Old Jan 29, 2005 | 10:06 AM
GrandSportC3
I might do that, or maybe I'll use some insulator on top of the main hoop.. Haven't decided yet.. It's not a show car...
Old Jan 29, 2005 | 10:08 AM
GrandSportC3
I actually want to finish most of the work this weekend.. Might fire it up tonight or tomorrow if I can get the pin from the distributor gear removed.. It's stuck and I f'd it up, trying to tap it out :banghead... I might even need a new distributor and gear...
Old Jan 29, 2005 | 10:10 AM
79VetteMike
Did you ever figure out why your cooling lines are so close to the tunnel? If I remember correctly, my trans didn't sit that close. Did you cover up those connections when you were cutting? Looks like fiberglass may have gotten in there. Also, are those gussets on the downtube behind your left shoulder where the bar disconnects going to be strong enough?
Old Jan 29, 2005 | 10:17 AM
Aflac's Avatar
Aflac
St. Jude Donor '09
if you have a good drill press and a tiny drill bit, you may be able to drill thru the pin and crush it into itself.
Old Jan 29, 2005 | 10:19 AM
GrandSportC3
I covered the ports with electrical tape while cutting... However, the dust is everywhere and might have gotten in there after I pulled the tape off... Not a big deal.. that't nothing that the filter wouldn't catch..
The body/drivetrain alignment was not consistent on early C3's, especially '68's.... . The clearance varies from C3 to C3...
Old Jan 29, 2005 | 10:20 AM
GrandSportC3
I tried that and broke off 3 drill bits.. Unfortunately, I don't have a drill press so I used a regular drill
To Project update...
Old Jan 29, 2005 | 10:21 AM
GrandSportC3
Heading to the speed shop. Need speedo gears...
redc3's Avatar
redc3
im loving this. im sure the guys who polish their chalk marks and build sheets are cringing in a closet somewhere
Old Jan 29, 2005 | 10:23 AM
Aflac's Avatar
Aflac
St. Jude Donor '09
take the distributor with ya... they may be able to help ya
