Hood alignment
Old Jan 30, 2005 | 11:49 AM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Hood alignment
Okay tommorow I'm starting the engine bay detail project. On my 77 if I recall I drilled 2 holes on each hood hinge so during reinstall I could slide a scribe down the hole to verify alignment. Question is I don't remember if the hinge had elongated holes on both the hood to hinge and hinge to body or just the hinge to body.
Want to drill the holes before I ever back off the nuts since the hood is perfectly aligned right now.
Old Jan 30, 2005 | 12:10 PM
Cali,68,L-79
ttt
Anybody? bueller, bueller.
Old Jan 30, 2005 | 02:01 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
When I removed the hood, I just scribed the hinge outline onto the hood. Worked for me.
Old Jan 30, 2005 | 02:13 PM
Paul L's Avatar
Paul L
David,
Surely a thin-point, water-soluble magic marker would do that job.
Old Jan 30, 2005 | 02:45 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
on my 77 the hinges are off of the car.....the body to hinge holes are a smaller round diameter then the hinge to hood holes....none of them are elongated but the hinge to hood holes certainly are a larger diameter...i just scribed the hood hinge....i tried blue tape but it would not stick........
Old Jan 30, 2005 | 07:04 PM
Cali,68,L-79
I'm going to scraibe them in. Remember I'm repainting the bottom of the hood so majic marker won't work but if I apply pressure the mark will show even when painted. Thanks all.
To Hood alignment
