Another TH200R4 question...
Old Jan 30, 2005 | 12:07 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Another TH200R4 question...
I'll need to know which one of the cooling ports is the one that the hot fluid exits and which one is the port that the cooled fluid returns??
I'm going to install a temperature sensor on the line that contains the hot fluid....so I need to know..
Old Jan 30, 2005 | 12:09 PM
page62's Avatar
page62
Its backwards from the TH350...that's all I can recall.
Old Jan 30, 2005 | 01:03 PM
GrandSportC3
ttt
Old Jan 30, 2005 | 01:09 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
GS - on another note. Watch out using rubber hose and clamps. I blew mine off twice with a performance 700R4. I finally took it to the tranny shop and had hard lines ran the whole way.
No clue on the line config. I gave my book away.
Old Jan 30, 2005 | 01:11 PM
GrandSportC3
I'll slip the rubber hoses very deep over the pipe.. I should be ok...
Old Jan 30, 2005 | 01:15 PM
Retro78's Avatar
Retro78
make sure you put a little flare on the pipe before slipping on the hose. I have seen some people try to use fuel line which of course will not stand up to the pressure and heat. I assume that you have the special trany rubber lines.
Old Jan 30, 2005 | 01:19 PM
GrandSportC3
I use braided rubber hoses from the speed shop...
Old Jan 30, 2005 | 01:21 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
ditto on flaring the end of the pipe. Use a brake line double flaring tool, and do the second flare about half way to get a bubble flare. On a Th-400, the return is the top port, don't know on your tranny.
Old Jan 30, 2005 | 01:33 PM
Riley's Avatar
Riley
On the bow Tie Overdrive info is says that the top line is the pressure out for the 2004r and the bottom is the pressure out for the 700r4. If you need any more info on this let me know as i have the intructions as i am just starting to install the 2004r from bowtie overdrive.
Old Jan 30, 2005 | 02:12 PM
redwingvette's Avatar
redwingvette
The top line is the pressure line and the bottom line is th return. Make sure you add a line filter in the return line for the first couple hundered miles to catch any break-in metal floating in there.
Old Jan 30, 2005 | 02:25 PM
shoptek's Avatar
shoptek
I blew off the rubber hose from my stock TH400 pressure side. :o
DITTO....Flare the fittings or go hard line.
Old Jan 30, 2005 | 02:59 PM
GrandSportC3
Thanks!!!
Old Jan 30, 2005 | 03:01 PM
GrandSportC3
Who has the flaring tool?? Harbor freight??
Old Jan 30, 2005 | 03:03 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
yeah i saw one there the other day.
Old Jan 30, 2005 | 07:38 PM
GrandSportC3
I bought it there and it works great!! Used it on the metal lines from the transmission.. Don't think that the hoses will ever slip off now!!
Old Jan 30, 2005 | 09:20 PM
comp's Avatar
comp
cool
Old Jan 30, 2005 | 10:48 PM
GrandSportC3
Originally Posted by comp
cool
Didn't want the cooling hoses to slip off in the middle of the track
To Another TH200R4 question...
