4 speed install tips?
Thanks to all that responded to my questions.
The auto is out and the flywheel, clutch disk, pressure plate, bushing and bellhousing are in. I cut the floor for the shifter and began to mount the 4 speed. Lots done since friday night...
But I have run into my next challenge...
I can't get the 4 speed mated to the bellhousing I just can't get it in the last 1/2 inch. I wiggle I shake I raise and lower the trans and engine, I rotate the trans and still can't get it in. I considered drawing it in with the bellhousing bolts but was afraid I would break off a trans ear.
Any tips? am I overlooking something? The bushing and through out bearing are correct size and the number of splines 26 match, the bellhousing fit on the bench.
I did leave the shifter attached to the trans, is this wrong?
Please respond if you have tips?
Thanks,
John
James
James
I would like to add two things to check.
1) Did you use a tool or actual splined shaft to make sure the clutch disc and the crank bushing are PERFECTLY in line.
2) Either have the proper plug for the tailshaft or have the tranny low on oil.
I had my room mate help me put a tranny in car when I was younger. He happened to knock the rag out of the end and dumped tranny fluid all over his crotch .
Do you have the clutch linkage hooked up? If so, you may be able to get that last 1/2" by having someone slowly push in the clutch.
NOTE!!!! If this is done incorrectly, the clutch disc can drop out of position and you have to take off the bellhousing and pressure plate to get it correctly lined up AGAIN.
James described the easiest way to get it in. Laying on your back with the tranny on your chest.
Good luck
Jeff
TJ
Hopefully with someone working the clutch is will jump in.
TJ
1. loosen bellhousing without tranny so you can move it enough for the tranny to slide into the pilot bushing
2. mount tranny to bellhousing (loosely but in all the way)
3. tighten all bolts
I got my a** kicked tonight too...
I have some questions.
How long did you make the studs for the bellhousing?
did you use 4 studs or just the top 2?
Thanks again,
John
I hope that having someone work the ctutch for you works, but if not, just redo it and bench-press that tranny right in. The last few millimeters will be taken up when you tighten the 4 tranny bolts - but 1/2" is too much for me to advise just tightening it all down and hoping for it to go in... Just my 2 cents...
Good luck!
Good luck!
I do have an alinement tool. I really hate to remove the bellhousing because its just a PIA but to re-aline everything thats what I must do.
The car is high on jackstands so I can't put the trans on my chest but I do have a floor trans jack (harbor freight) and my plan is to stud the bellhousing and slowly roll the trans on to the studs and with any luck (good luck this time) guide it home..
What makes this tough is I am doing all the work by myself. (I can get my 12 year old to push in the clutch)
Thanks for all your advice
John
Just a suggestion.
Just a suggestion.
I pulled the bellhousing and realined the disc again with my alinement tool (it looks perfect)
tried the bellhousing studs , same problems. just cant get that last 1/2 inch. I even tried to put it together without the throwout bearing just so I could see it go together still no luck
Thanks for the suggestion, The parts for this conversion for the most part came from a 73 but the bellhousing I had to find. I have read somewhere that a L-48 had a different clutch fork stud than a L-82, why I do not know.
Can you tell me what length the short and long studs are?
thanks,
John
I went throught the same problems. Had the bellhousing off half a dozen times, trans out a dozen.
The cheap alignment tools are junk.
Had a friend and his girlfriend come over, she pushed the clutch and we wiggled the trans. It was in, in 20 secs.
If your 12 yr old can push the clutch get somebody to help wiggle and push the trans.
Best of luck, it's a pain, but it will go.
Terry
Terry
Thanks for the encouragement. I tried that the other night but I had found that the disc was off some. I will try it again.
John
