calling ALL 383's
Old Jan 31, 2005 | 09:35 PM
  #41
carl a's Avatar
carl a
my 383 has 10.5 to 1 comp ratio with a 488 lift 302 dur. crane fireball cam, the stock heads were re-worked to 2.02 intake , i changed out the stock ignition to msd tach drive dist, with the 6a-L box , still running the stock(jet coated ) exhaust manifolds with (jet coated) 2.5''chambered exhausts ,,the rear end is 373 and i have installed a high preformance 700r-4 overdrive trans,,fiberglass mono spring, total (new frame-por-15 ed,,outside z-barted inside) body off restoration using 85% new parts(calipers rotars stainless brake and gas lines all stainless hardware including parking brake hardware, new body paint and engine compartment paint and undercarrage paint. every frt end part and every metal part under the car was 2coats por-15 with metal mask top coat and glisten p.c gloss coat (to look like bare clean metal) entire frt end ball joints steering ect is new--and thats all i got to say about that!! also car has taken 1st place at chevy vette fest 4 time in a row with a high score of 995 points outta possible 1,000---
Old Jan 31, 2005 | 10:06 PM
  #42
Ryan77's Avatar
Ryan77
71VetteLT-1:
I'm just finishing up the install of my 383 from AR Racing. The motor they built for me is: 383ci, 10.5:1 compression, completely forged bottom end, Comp Cams 288HR, Canfield aluminum 200cc heads (ported to 205cc, bowls blended, 2.05/1.60 valves), Weiand Team G sinlge plane intake, 1.5 roller rockers. They said a mule engine of this combo made 525hp@6200rpm. Of course this was at the crank and probably had no accessories hooked up. I'm hoping for about 425hp at the wheels
Old Feb 1, 2005 | 12:09 AM
  #43
71vetteLT-1's Avatar
71vetteLT-1
again, i dont see how that motor (with smaller heads) is making 100 more horsepower than the one we are looking at...are the canfields THAT much better than pro 1s?????
Old Feb 1, 2005 | 08:15 AM
  #44
LFZ's Avatar
LFZ
I think that AR motor is a very nice combination. The motor you talking about that makes 415hp sounds like its just got the wrong parts..Pro 1 heads with an Air Gap, 600cfm Edelbrock carb, and who knows what kind of cam..probably something around the high .480 lift....it just sounds like a bad combination for the hp your expecting, therefore, 415 sounds about right.
Old Feb 1, 2005 | 03:23 PM
  #45
71vetteLT-1
yeah, thats exactly what i was thinking, here is a link to an article on Chevyhighperformance.com where they used almost the same exact components and they were able to make 524 horsepower and 512 Torque...the only diff. are smaller intake valve, Speed Demon Carb, 8.5mm wires, and the heads are ported a little...
http://www.chevyhiperformance.com/te...es/0304_zoops/
Old Feb 1, 2005 | 05:36 PM
  #46
redc3's Avatar
redc3
still on the stand but so far mine has steel aero crank, reworked factory rods, forged and coated pistons, motown -2 heads ( 2.08 /1.94 valves )220 cc intake runners, 64 cc chambers, port and polish by me, all comp cam valvetrain, 5.25/5.25 lift, 307 duration at .006 lift, 110 lobe sep with ground smaller basecircle. planning on speed demon with air gap. already have heddman long tubes, ceramic coated. and i was giggling like a girl watching grandsports burnout. HEY grandsport. you still running IRS in that thing?
Old Feb 1, 2005 | 05:40 PM
  #47
redc3's Avatar
redc3
oh i forgot.... mallory ignition, 8.5 msd race wires, aluminum high vol. watepump, milodomn windage tray oilpan, holley hi po mech. fuel pump and dual electric fans. and im gonna run a flattened x pipe under the diff with flowmasters. what do yall think?
