i have headlights, but no highbeams?
Old Jan 31, 2005 | 05:56 PM
81corvettevortec's Avatar
81corvettevortec
Default i have headlights, but no highbeams?
i just had my new engine dropped in my car, and ever sinse my highbeams don't work. well actually my headlights work fine, but once i flick to highbeam my headlights go off! everything else stays on and works fine, just all the outside lights shut off? just wondering if anyones got a clue to whats going on. thanks again.
Ryan.
Old Jan 31, 2005 | 06:24 PM
81' Corvette Guy's Avatar
81' Corvette Guy
high beams out??? you check for voltage to the high beams..with at least a test light..better yet a voltmeter..try it and get back to us! Joe!
Old Jan 31, 2005 | 09:19 PM
kdf1986's Avatar
kdf1986
Do all of the parking/running lights go out? Or just that the Hi Beams do not turn on.
kdf
Old Jan 31, 2005 | 11:10 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
MIne started doing this after I rebuilt the column. Everything goes out. I haven't tested the switch yet.
Old Jan 31, 2005 | 11:26 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I would be looking for a bad ground. There's a engine to frame strap near the starter and right side motor mount, there are also grounding wires from the headlights to the hood surround that could have been disturbed during the engine swap.
Old Feb 1, 2005 | 12:58 AM
FinnShark's Avatar
FinnShark
Grounding is a good guess, if that doesn't help check the foot switch. I had problems with that swiicth and it did exactly the same for a while. After a while it get worse and even the low beams weren't working...
Old Feb 1, 2005 | 03:43 PM
81corvettevortec
as soon as i go to highbeams all the lights shut off, i will take the advice tho and check all the grounds! thanks again.
Ryan.
To i have headlights, but no highbeams?
