replacement speakers???
Old Feb 3, 2005 | 02:04 PM
neoh77's Avatar
neoh77
Originally Posted by pgtr
Matt you sound like you know your stuff... I don't mean to hijack this thread but I have a couple few questions you might be able to help with and may be relevant to this thread...
I'm contemplating building a custom pair of speakers for a mid C3 w/ the dual DS-501 transistor stereo amp. The 662 factory 'upgrade' speakers are about as good as it gets for drop-in replacements, they are the correct 10 ohm speakers and all of that. But while way better than the originals - still not an ultimate hi fi speaker even for a vintage 68-76 amp. (FYI the later amps especially 74-76 are I think a lot better than earlier amps).
As you probably know these mount under the dash facing up and focusing on the windshield glass. THeir baskets are open and explosed to the dash and ultimatley footwells below...
As you know nice separate drivers exist including 8 ohms. Again for an original amp I was thinking of putting together a 4X6 plate w/ cutouts for say a 4" driver and a 1" tweeter and a crossover. THoughts...? Any idea how much better this might be over the ACDelco 4X6 10 ohm given an amp that puts out a couple few watts on a good day?
The other question applies equally to ACDelco 4X6s or a 'custom' speaker and that is enclosures for the face up dash speakers open to the bottom... I was toying w/ the idea of a 4X6 foam baffle and some polyfill in there. No it's not a serious rigid enclosure but perhaps it would be better than an 'open' speaker...? Or is it worth the trouble?
Crutchfield offers XTC Foam baffles in 4X6 w/ either a 3.5" depth or shallow 2.5" depth. The guages on the passenger side probably force the 2.5" depth.
And given a baffle like this - worth cutting a small hole in bottom or not?
I know there are other options like kick panels or rears but right now for this particular project only the original dash mount 4X6 location is an option. And the speaker needs to be at least 8 ohms. Those are THE constraints for this project.
thanks!
Let me rewrite this again after reading through your question. The XTC foam baffles are really meant to keep the dirt and moisture away from the driver. I don't think you'd see a difference sound quality wise. Car speakers are designed with free air operation in mind like a door or dashboard. You're hard part will be finding something that is 8 ohms on the market. The 4" coaxial speakers seem to sound a little better than any 4x6" speaker I've heard. MB Quart makes some decent 4x6" drivers in the Discus series except they are also 4 ohms.... Any speaker of that size won't yield great bass... an 8" sub tucked away in the back would fill it out from 100hz and down.
Were you thinking something like this? Again, stuck at 4 ohms.
http://www.crutchfield.com/S-iDBQqYp...0&I=1086402CFP
That said...my vette stereo is bone stock. The engine noise makes me want to hear the radio a lot less! =)
I'll keep looking for something 8 ohms... what a pain!
-Matt
FYI the resistor trick doesn't work Been there... screwed that up.
Old Feb 3, 2005 | 02:44 PM
C8H18's Avatar
C8H18
Yep I understand they are really just intended for protection but was thinking (hoping) they'd be able to offer 'some' properties of an enclosure... I can see a door or even a trunk as a kinda sort enclosure but the dash is just plain WIDE open to the bottom was my concern and providing a dual open path for waves.
Well gosh dangit! I deleted teh link - but I was at a site just the ohter day that had a whole page of 4" 8 ohm drivers. These were just basic speaker components - not packaged as complete ready to install speakers but for making customer speakers with (e.g. no grills, not sold in pairs...). What caught my attention was the poly surrounds and massive magnets a few had. Sensitivity was in the high 80s to low 90s. These could have been intended for home speaker design for all I know - I didnt' save the darn link unfortunately.
Indeed. heh heh - keep in mind the 'reference' here would be the GM 662 'upgrade' 10 ohm 2-way 4X6s made in Mexico and costing $24ish ea. (And for a real joke you should see the original 70-76 4x6s!!!)
Precisely - a custom fabbed 4" & 1" that would end up looking just like that w/ a crossover and using 8 ohm drivers. The tweeters all seem to have greater db sensitivity but between a tone control and given a noisy car environment I think that's perfectly fine.
-Matt
I didn't mean to set you off on a hunt - just wanted to pick your brain a bit was all and maybe set me straight a bit...
Agreed - I think we've all at least thought of that one at some point. It makes for a very innefficient speaker.
Old Feb 3, 2005 | 03:57 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Please allow me to clarify the Delco part number 13033662 speakers (4 X 6) I recommended near the top of this thread are intended for in dash, not kick panel. If GM does not have the 4 X 10 kick panel speakers, I would recommend trying to fit the 4 X 6 speakers in the kick panels with an adapter. There's a good chance if those 4 X 10 speakers were a 2 year only, GM may not have them. Crutchfield lists nothing even close, not even modern 4 ohm speakers in that size. If you would like to try a 4 X 6 speaker for fit, I would be happy to send you one of my originals, but it is no good. Use for test fitting only. PM me your address if you want it.
Old Feb 3, 2005 | 04:28 PM
68sbShark's Avatar
68sbShark
I'm gonna review the wiring diagram again. But here is my thought. I plan on wiring the 2 speakers in series, which should result in an approx 10 ohm load. This is a mono radio so this should work. Any ideas on this from you audiophiles???
~Rich
Old Feb 4, 2005 | 02:25 PM
68sbShark's Avatar
68sbShark
Well, after speaking to several audio guys that have been doing Delco radio repair for a while, I have been told that using a 4 ohm speaker will be OK. One guy told me that a Delco can handle 4, 8 and 10 ohm without any negative results, as long as I don't go below 4.
I guess I'll give it a shot and see what happens.
Thanks all for your replies. Much appreciated, being my first post and all.
~Rich
Old Feb 4, 2005 | 04:14 PM
C8H18's Avatar
C8H18
~Rich
Did you speak w/ techs experienced with older vintage Delco radios? As in pre 77? Are they familiar w/ the performance limitations of teh DS-501 Delco transistors? Have you priced or checked availability of these vintage transistors? Running 4 ohms will STRESS the amp and that will be especially true of sustained operation and/or higher volumes.
What they are saying is true of the newer Delco radios of the mid 70s and beyond (which continued to use 10 ohms) but I will strongly disagree as far as the vintage Delco radios in pre 77 Corvettes that used the old DS-501s.
That being said based on the posts above I do kinda wonder if the Zip speakers being 4X10s are by definition GM and 10 ohms despite their lack of stampings.
Good luck!
Old Feb 5, 2005 | 12:11 AM
Big Fish's Avatar
Big Fish
Here's a good guy to talk to. His specialty is Corvette Radios, 1968-1976. Other radios built from 1950-1976. Gordon Ward of Huntsville, Alabama. Phone 256-892-0955 or e-mail glw@mchsi.com
Surely you will need someone with his talents sooner or later. He did a great job fixing my radio.
Old Feb 7, 2005 | 01:49 PM
68sbShark's Avatar
68sbShark
Just sent him an email. Thanks for the contact info. Hope he can help me out.
~Rich
