Short spark plus?
Old Feb 1, 2005 | 06:07 PM
Jclgodale3's Avatar
Jclgodale3
Default Short spark plus?
Is there a "short style" spark plug that will fit in my 350 in order to help the wires run behind the header tubes along th block? The current R44t's push the wire out to far even with the elbow to run the wires behind the tubes. Specific part number if so? Performance issues?
Old Feb 1, 2005 | 07:39 PM
vettfixr's Avatar
vettfixr
I don't have a part number for you but I believe Accel makes shorty plugs for headers. You can check Summit or Jegs.
Old Feb 1, 2005 | 08:23 PM
oregonsharkman's Avatar
oregonsharkman
Accel shorty yellow header plugs
Old Feb 1, 2005 | 08:30 PM
cw823's Avatar
cw823
That's what I run. I still find that for cylinder 4 I have to run the cable towards the front, then loop it around to the back so it clears the header.
Old Feb 1, 2005 | 08:41 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Is that the whole number R44T or is there more ? I come up with an NGK part number YR55VX. I use the NGK plugs as they are identical to the Accel shorties, just not yellow and half the price.
Old Feb 1, 2005 | 11:50 PM
Jclgodale3's Avatar
Jclgodale3
no, the whole number is R44TS and they are AC Delco plugs currently...
Old Feb 2, 2005 | 12:25 AM
Jclgodale3's Avatar
Jclgodale3
Motorhead...who carries the NGK's? Thanks
Old Feb 2, 2005 | 08:24 AM
MotorHead's Avatar
MotorHead
I get mine from Jegs or Summit but other stores carry them too, I will crossreference the R44TS when I get home tonight
Old Feb 2, 2005 | 11:16 AM
PureSilver's Avatar
PureSilver
my friend is dealing with this, and if you aluminum heads (requiring a deeper threaded section of the plug) you may not be able to get the shorty type. You may need to dimple your headers for this.
Old Feb 2, 2005 | 02:16 PM
mrvette's Avatar
mrvette
I"m running R45TSX.....I think the S means short shank...not sure about anything else...
GENE
Old Feb 2, 2005 | 02:31 PM
pws69's Avatar
pws69
GENE
T = Tapered Seat
S = Extended Electrode (Tip)
X = Wide Gap (HEI)
MANY people use the -T versions when they shouldn't.
Old Feb 2, 2005 | 08:11 PM
MotorHead's Avatar
MotorHead
R44TS = UR4 NGK
R44TSX = UR45 NGK
Old Feb 2, 2005 | 10:38 PM
greyghost79's Avatar
greyghost79
anybody running Iridiums? and can you tell me what makes a spark plug worth $12+ a piece?
Old Feb 2, 2005 | 10:42 PM
MotorHead's Avatar
MotorHead
The only thing that makes them worth 12 bucks a piece are the people that buy them
Old Feb 2, 2005 | 10:48 PM
mrvette's Avatar
mrvette
Originally Posted by pws69
T = Tapered Seat
X = Wide Gap (HEI)
I remember holding two plugs next to each other in a store one time some 2 years ago, and looking at the white shank the wire is on..and finding the TSX was shorter on the ceramic measured from seat of the plug/taper to plug/wire end....and so chose the TSX, as the differance was about 1/8+ inch....
I can't remember much else but it was enough that with fabricated metal shields clamped to the headers going between the plug boots and header tube, it cured the burning....
GENE
To Short spark plus?
