Alright guys, please don't flame me here.. I'm kinda new to all of this and very interested!
I was wondering what determined the compression ratio. I have a 350 c.i. engine and I found out that the my block is from a 69 vette and the heads are either from a 72 or a 73 vette. I have no idea what cam I have... Is there any way to find this out without taking the engine apart?
Pistons determin the Compression ratio. And there was more than one engine available in 69. If you give me your engine casting # I could tell ya what it came with it. But it's impossible to know what's in it unless you open it ( old owner may have mod it )
CR for you is mainly a function of cylinder head chamber volume in cc's - easiest to know what was stock and what you have now, and dome volume of your piston (also in cc's). For my car, the stock CR is a whopping 8.25:1. They used flat-top pistons (dome volume is zero), and 123cc heads. If I use 110cc heads, then I get a higher CR - about 9.3:1 or so. If I use my heads and 25cc domed pistons, I get ~9.5:1 CR...
The wild card for you may be figuring out what pistons are in your block. You may have to pull a head to see...or use a borsescope like a few guys here have...
