Radiator DIY install
Old Feb 2, 2005 | 09:13 AM
Blackened 79's Avatar
Blackened 79
Default Radiator DIY install
I'm going to attempt to change my 25 year old leaking radiator...In checking the Chilton repair manual, 77-82 doesn't specify removing the hood, but for earlier C-3's it does. Can anyone that's done this themselves give me some pointers and let me know what to look out for ?
Old Feb 2, 2005 | 09:16 AM
Stewart's74's Avatar
Stewart's74
Do yourself a favor and remove the hood. Much less aggrivation.
Old Feb 2, 2005 | 09:22 AM
Hvymtlc5's Avatar
Hvymtlc5
Very much agree, and it (hood removal) ain't no big deal either..
Old Feb 2, 2005 | 09:25 AM
COMMANDER370's Avatar
COMMANDER370
Removing the hood made my change out much easier
Old Feb 2, 2005 | 09:46 AM
Glassbowtie77's Avatar
Glassbowtie77
I replaced my radiator and core support without removing the hood, however if I had to do it again I would remove the hood. It was a tight sqeeze but I did it. The hardest part was removing the shroud, with the hood off you can move the support further forward to give you more room to get it past the upper a-arm on the drivers side.
Old Feb 2, 2005 | 11:15 AM
Red 69's Avatar
Red 69
Trace around the hood latches before you loosen the bolts. Those marks will make reassembly much easier.
Old Feb 2, 2005 | 11:50 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
heres a picture of a 77 install.. the radiator slips between the shroud and the core support on a 77...i think its the same on a 79...
the shroud is resting on the water pump...
[IMG][/IMG]
the radiator slips between them...
[IMG][/IMG]
Old Feb 2, 2005 | 12:53 PM
RATT7's Avatar
RATT7
I removed the rad on my 1980 and did not have to remove the hood. I first started by draining the rad and removal of the hoses. I then removed the ducting on top of rad and then was able to slide the rad shroud over top of the fan, once I completed this the rad came out pretty easy with the assistance of a second person so that the rad was pulled straight up. The only problem was the install, I found that the bottom neck portion of the rad was difficult to get past some of the front end assmebly on the car. Some of the members have discussed this and mentioned that loosing an arm would allow you to slip the rad back in without the lower neck of the rad interferring. Hope this helps.
Old Feb 2, 2005 | 01:52 PM
87bob's Avatar
87bob
Veteran: Coast Guard
I had the same expirence. I solve the shroud problem I cut it at the bottom and then made a metal bracket to rejoin the halves after I got it all installed. I would also reccomend having several buddies standing by to lend a hand on both removal and installation.
Old Feb 2, 2005 | 04:22 PM
1978shark's Avatar
1978shark
When I did mine I had the fan, shroud, clutch, water pump, and all the hoses out of the car. Figured if I was going to work on the radiator might as well go back with a new pump and hoses. I didn't remove the hood. Looked a little too heavy and difficult to control for one person to remove. Two words of caution: 1) watch out where you take your radiator. The brass and solder is very fragile and if they aren't careful will do more damage than good. 2) The bottom support will be rusted. Get ready to either POR what is left or replace it.
Old Feb 2, 2005 | 07:49 PM
redc3's Avatar
redc3
after reading posts on this subject before, early c-3's are a giant pain. on my 78, i pulled the fan, layed the shroud on the engine and pulled that puppy out! thats it! ive heard other guys say they even pulled a-arms ....... one rad, one man, one hour
Old Feb 2, 2005 | 08:07 PM
BerniesVette's Avatar
BerniesVette
I can't imagine taking the hood off just to pull the rad. I pulled mine by myself with no problems with the hood on. The rad is slanted anyway and comes out that way. Drain the rad, remove the hoses and fan, unbolt the rad and then pull it out. Leave the shroud laying against the engine until you replace thae rad.
Bernie
Old Feb 2, 2005 | 09:47 PM
fauxrs's Avatar
fauxrs
Did my radiator - 1 man two hours in an unlit garage - did not remove the hood.
Would it be eaiser?
....sure.. more access is always easier
would it add the possibility of more things going wrong?
...sure, you could drop the hood - it could fall over - you could fail to get it aligned properly making it difficult to close and/or open.
If you have the time...take the hood off...no harm there...
If you dont want the annoyance of having to realign the hood.. leave it on...you can do the job with it there anyway.
Old Feb 2, 2005 | 09:50 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
When I did mine, all i did was drain it, remove the hoses, undo the fan & clutch assembley and slide the radiator cowl back. sure, taking the hood off would make it easier, but why take off more than what you absolutely need to? That's just inviting more headaches!
Old Feb 3, 2005 | 03:26 AM
EVIL_GRIM's Avatar
EVIL_GRIM
i cut my fan shroud in about 20 pieces before finding out how much it was worth Then the 3-core radiator came out, and a 4-core went in.
Old Feb 3, 2005 | 03:37 AM
Secret Squirrel's Avatar
Secret Squirrel
Instead of writing on the hood and marking it up, put some masking tape
against the edges
Old Feb 3, 2005 | 05:32 AM
djcwardog's Avatar
djcwardog
For my car the hood comes off... You might have an easier setup and not need to pull the hood. Just start pulling off the stuff and see if you need more room. If you do, stop and pull off the hood (with the help of another person).
Old Feb 3, 2005 | 06:34 AM
Gary79's Avatar
Gary79
no need to pull the hood, i've pulled the radiator on my 79 a couple of times, it's nice to have a person on either side of the rad when pulling it out, a little easier on the back, you'll also have a little more control if you use a second person when putting one back in.
Old Feb 3, 2005 | 03:33 PM
redc3's Avatar
redc3
against the edges
drill a small hole before you loosen the bolts. when you re-install use the bit as a guide, and lock the bolts down. no paint, no tape
To Radiator DIY install
