Broken Spring
Old Feb 2, 2005 | 10:14 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Broken Spring
Here is a pic of a broken leaf on a steel spring. Customer came in yesterday to get a new steel spring from Eaton, which by the way was arched incorrectly. We had to use 10" bolts for his steel spring.
Old Feb 2, 2005 | 11:07 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Why not use a spring that IS arched correctly and use the standard bolts?
What if the customer wants to lower the rear. How will he do it now that there are 10" bolts already in place?
Old Feb 2, 2005 | 11:21 AM
GTR1999's Avatar
GTR1999
Where can you find a replacement spring that IS correctly arched????
As far as I know(which might not be much ) the only springs available are made in Canada,Mexico, or Eatons? I used the Mexicans spring and they don't work any better. If I had a stock pile of NOS GM springs they'd be worth more then some C3's!
Gary
Old Feb 2, 2005 | 11:39 AM
Matt Gruber's Avatar
Matt Gruber
got the canada spring 10 yrs ago. no problem
Old Feb 2, 2005 | 11:44 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Broke my steel spring about 2 years ago..
Unfortunately - it broke off at the end ...
Old Feb 2, 2005 | 11:46 AM
mrvette's Avatar
mrvette
Two words....
Fantastic Plastic.....
GENE
Old Feb 2, 2005 | 11:47 AM
AGVI's Avatar
AGVI
Where did you get it?
Old Feb 2, 2005 | 01:41 PM
isosceles's Avatar
isosceles
should I replace my steel spring and save it for posterity?
Old Feb 2, 2005 | 02:24 PM
Tom454's Avatar
Tom454
"If I had a stock pile of NOS GM springs they'd be worth more then some C3's!"
I do have a pile of OEM springs. Saving them for my retirement.
Old Feb 2, 2005 | 02:57 PM
Matt Gruber
corvette central
Old Feb 2, 2005 | 03:28 PM
Frankenvette's Avatar
Frankenvette
Based on the comments posted in this thread about aftermarket springs, here is what you will now see if someone decides to sell their spring on ebay.
" Very Rare original C3 rear steel spring. Not sure what year this came off of, but it's in perfect condition with just a little surface rust. Will improve the performance of any C3. Don't miss out on this one of a kind sale."
Bid starting at $150.00
Buy It Now $300.00.
Old Feb 2, 2005 | 04:18 PM
Van Steel's Avatar
Van Steel
The guy did not buy the spring from me. He got it himself and bought it in. His spring, his deal.
Old Feb 2, 2005 | 04:20 PM
Van Steel's Avatar
Van Steel
Gary
Eatons are now made in Mexico. They moved their whole plant over there late last year. I buy mine from a local spring shop and only had 1 problem ever w/them. They corrected it the same day.
Old Feb 2, 2005 | 04:36 PM
GTR1999's Avatar
GTR1999
Dan that's a good sign if you have a local shop fab them up. I spoke with a spring shop here , a pretty good size on too, and they didn't want to be bothered with corvettes! Do you still need to use 8" bolts with them or will the 6.25 stock bolts work?
The mexican springs I have came from CC about 4 years ago and need 8" bolts. Another 7 leaf steel bought from another well known vendor was the same way.
I heard of Eaton spring and it was mixed reports, sounds like the rest.
I don't like the glass springs too much so there's not much to choose from.
I would be concerned buying a used spring off ebay.
Gary
Old Feb 2, 2005 | 04:40 PM
redvetracr's Avatar
redvetracr
Originally Posted by mrvette
Two words....
Here is one for you "flexiflyer".......too much bounce...
...redvetracr
Old Feb 2, 2005 | 04:45 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
...redvetracr
I don't get any bounce out of my dual mount
Old Feb 2, 2005 | 04:49 PM
nostgry's Avatar
nostgry
Got my new leaf from Muskegon Brake. Worked great. I think it was $89.00
To Broken Spring
Old Feb 2, 2005 | 05:02 PM
i885744's Avatar
i885744
well, let's see, that factory air cleaner wing nut went for $30 something on ebay, so a 7 leaf rear spring from a 73 is worth what, 5-6 thousand dollars? I'm accepting bids now. Love my vbp fiberglass spring!
Old Feb 2, 2005 | 05:20 PM
1979toy's Avatar
1979toy
Don't forget the 2 engine mount bolts that went for something like 215.00 NOT including shipping.
Old Feb 2, 2005 | 05:32 PM
stingr69's Avatar
stingr69
My factory steel spring has a cracked leaf in it AND one leaf was formed upside down. The tapered end is bent the wrong way. Still has the slopped on gray primer paint and broadcast code stamped on it. I wonder if GM would warranty the one bad leaf?
Just for reference, I have an old AO Smith/TRW fiberglass spring on there now and the ride height is fine. One of these days I will have to go measure the bolts as I know they are not the factory ones. The Bilsteins cured the bounce.
-Mark.
