Caliper Paint?
Old Feb 3, 2005 | 07:26 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
You painted the rotor too???
Old Feb 3, 2005 | 08:19 AM
VetteNut72's Avatar
VetteNut72
Not the rotor surfaces or the hub, just the outside edge and vanes. I really don't see any factor in that, in fact, I really like it. Oh, and the brake pads as well, and again, no paint on the pad material
Craig
Old Feb 3, 2005 | 08:26 AM
norvalwilhelm's Avatar
norvalwilhelm
Mine were done years ago with a regular spray bomb.
Old Feb 3, 2005 | 08:34 AM
CGGorman's Avatar
CGGorman
PlastiKote Engine enamel.
Old Feb 3, 2005 | 08:50 AM
Hvymtlc5's Avatar
Hvymtlc5
Rustoleum (sp?) sunrise red is the ticket. Been on mine and buddy of mine's C5 for over a year with no problems.
Old Feb 3, 2005 | 09:21 AM
kens 80's Avatar
kens 80
Believe it or not I did a c-5 with Sikkens body paint on a friends car 3 yrs ago. He wanted to match the body color(magnetic red). This is a three stage paint as is is pearl. Job took all weekend cleaning,three applications of paint/pearl/clear. Then had to bring back the factory "CORVETTE" lettering on the fronts.Bottom Line, looks great, nobody else has it, and its holding up fine.
P.S. Materials cost almost $100.00
Old Feb 3, 2005 | 09:46 AM
superdad60's Avatar
superdad60
Maybe just the outside edge?
Old Feb 3, 2005 | 10:29 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Originally Posted by Turbo-Jet
just make sure it is red
Make sure it's not red! Go with black or silver.
Old Feb 3, 2005 | 10:38 AM
NHvette's Avatar
NHvette
I just got my VBP Oring rebuild kit yesterday.
After cleaning, I am going to use POR-15 silver.
Fluid proof and rust proof.
I don't know about you guys, but I always drip some fluid
when bleeding brakes. Enamel is a no-go for me.
OK - maybe, but then you gotta go with silicone fluid.
Old Feb 3, 2005 | 11:48 AM
rosslato's Avatar
rosslato
Originally Posted by burnz27
Duplicolor caliper paint kit, sold at WalMart and Autozone (at least the 2 I know of) comes with cleaner, paint and hardener to do all 4.
me too, in the red. looks very wet
Old Feb 4, 2005 | 10:20 AM
UKPaul's Avatar
UKPaul
I bought a set of unused VBP O ring callipers from a forum member & they had been painted silver with what looked, felt & behaved exactly like Hammerite. As I was going to paint them with silver Hammerite anyway, I just painted on a couple of coats to cover the chips & fitted them to the car in place of the stock ones (which I'd painted with silver Hammerite ). It's not a paint for those who want a perfect finish, but it resists the heat (been using it for years), is easy to apply, is fairly tough & resists dirt buildup. Easy to clean as well, just brush on some engine degreaser & wash it off. If you just want the callipers to look OK & the finish to be low maintainance (ie you haven't got the time/inclination to spend time cleaning callipers) then it's good stuff. It's looks a lot like thick powder coat with bad orange peel effect (the "Hammered finish". There's also Smoothrite but it takes longer to apply as brush marks & runs stand out, so you can't just slap it on in the same way). Brake fluid melts it but I've found that any fluid I spill on it when I bleed the brakes (& I always get some on it) doesn't do any harm as long as I wipe it off fairly quickly. Other finishes I've tried (eg 2-pack paint) lift immediately fluid touches it. Wouldn't recommend it for use on rotors as extreme heat will damage it.
As i said, it's not for show cars, but if you want a good low maintaince protective finish it's good stuff. With 2 years of use on the Vette the hammerite looks the same as the day I painted it on.
Anybody still running the stock caliper set up should consider changing to the VBP O ring setup. No leaks, no frigging about bleeding the brakes every spring, no fluid running down the inside of the tyres over the winter, no melted caliper paint(!) from seeping seals, no nasty surprises when the brakes are needed, etc, etc, etc. At last, brakes as reliable as any other car. Do I get my free VBP T-shirt now?
Old Feb 4, 2005 | 01:14 PM
MN-Brent's Avatar
MN-Brent
I used the RED Duplicolor caliper spray bomb during my rebuild. They look great after 2 years of driving it that way.
Cleans up well with a simple wash cloth too! See pic under avatar
Brent...
Old Feb 4, 2005 | 01:19 PM
  #33
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
I used the G2 Brake Caliper Paint System. Red, of course!
Old Feb 4, 2005 | 01:38 PM
  #34
COMMANDER370's Avatar
COMMANDER370
Make sure it is Bright Red
Old Feb 4, 2005 | 01:46 PM
  #35
timbo79's Avatar
timbo79
VHT
