Initial Timing Problem
Old Feb 2, 2005 | 09:59 PM
jdmick's Avatar
jdmick
Default Initial Timing Problem
I finally got my new 350 HO installed and started it. The initial timing is supposed to be 10 degrees but it won't run with less than about 15 and better at around 20. I have to guess since the indicator only goes to 12. What's the problem here. Thanks.
Old Feb 2, 2005 | 10:10 PM
greyghost79's Avatar
greyghost79
damper ring may have slipped. you'll need to check to be sure #1 piston is at TDC when timing is at 0 degrees.
Old Feb 2, 2005 | 10:16 PM
jdmick's Avatar
jdmick
It's a new damper and it's keyed so it can only go on in one place right? Is it possible for the groove to be in the wrong place?
Old Feb 2, 2005 | 10:31 PM
Simmo's Avatar
Simmo
Check your engine at top dead centre matches the marks on your damper.
Old Feb 2, 2005 | 10:59 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
what makes you think there is a problem? i tried getting my new 350/350 to run at 8* because thats what the Haynes manual says for a 77 and it didn't like that at all...turns out my new engine had nothing similar to the original L48, and 8* was not enough for my new engine..... i think i'm at either 14* or 16* and the car runs great.....so i would reexamine the spec and try and determine why they gave you that ......
Old Feb 3, 2005 | 01:08 PM
lars's Avatar
lars
There's no problem. Set the car up for 36 total timing. That should bring your initial up into the 16-20 degree range. 18 initial is optimum for a performance engine. The 10-degree spec is published for an engine that needs to pass emissions, and will not work well for a performance application. Set it up for total timing ad just verify that this gives you at least 16 initial. More is usually better (I run 24 on mine).
Old Feb 3, 2005 | 01:21 PM
mvftw's Avatar
mvftw
Old Feb 3, 2005 | 01:49 PM
CGGorman's Avatar
CGGorman
What other symtoms come of too-low initial timing? No start/hard start, rough idle, run-on, etc.?
Old Feb 3, 2005 | 01:58 PM
comp's Avatar
comp
let us know
Old Feb 3, 2005 | 02:10 PM
lars's Avatar
lars
Sluggish performance and high water temp.
Old Feb 3, 2005 | 02:14 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
How do you set timing with a vacuum gauge? Im planning on doing it this way this spring.
Old Feb 3, 2005 | 04:03 PM
lars's Avatar
lars
You can't. Setting it with a vacuum gauge will only determine rough initial timing setting. Initial timing means nothing - you need to set up for total timing, and this can't be done with a vacuum gauge. Use an adjustable timing light and set the total to 35-36 degrees. This will produce optimum power and best throttle response.
Old Feb 3, 2005 | 06:03 PM
bobs77vet's Avatar
bobs77vet
Lars thanks again for taking the time to help us out i can tell you we all really appreciate....thks bob
Old Feb 3, 2005 | 08:17 PM
greyghost79
24 initial, really lars???? so do you then only have 12 mechanical to get to the 36. do you have any hot start problems with that much initial timing???
Old Feb 3, 2005 | 08:57 PM
C3 Stroker's Avatar
C3 Stroker
...Mine runs best with 22 deg. initial and 38 deg. total timing; not unusual for a high performance engine. Easiest timing is done with a "dial back" timing light - set the dial at 36 deg. or your desired total advance and align the timing mark with zero at the RPM your total comes in & you're done.
Old Feb 3, 2005 | 09:22 PM
redc3's Avatar
redc3
can lars give us a step by step?
Old Feb 4, 2005 | 09:01 AM
mvftw's Avatar
mvftw
I'm sooo glad other guys have the same timing as me. I followed Lars method and also used his advance kit and my initial is about 22* with 36 & 52. I thought it was high but the cars runs fine. Now I know I'm Ok...
Old Feb 4, 2005 | 09:11 AM
lars's Avatar
lars
Yes, I have modified my distributor advance slot to produce only 12 degrees of centrifugal advance. This gives me 24 initial and 35-36 total. I run a B28 (VC1810) vacuum advance control unit that gives an additional 16 degrees of vacuum advance, and I run it off a manifold vacuum source. I have no hot start problems (9:1 compression), and the car runs very strong.
Since I do things with my own car that I wouldn't recommend as a general practice to other people, I conservatively recommend 18 degrees as a very good initial timing setting with an 18-degree centrifugal advance curve for 36 total. This will almost always perform exceptionally well in any performance engine, and is a solid baseline from which to start tuning.
redc3: Step by step instructions are published in my tech papers posted on Forums all over the Internet. If you want a clean, up-to-date copy in MSWord format, drop me an e-mail request to:
V8FastCars@msn.com
Old Feb 4, 2005 | 10:59 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
18* initial with 19*mech. all in @ 2000 rpm here with manifold vacuum "Varoom Varoom"
To Initial Timing Problem
