Everything on the car is hooked up and ready to go... I actually already lined up the timing mark with approx. 0 degrees and got ready to drop in the distributor.. I've done this several times on my old engine and never had any issues...
This time, the distributor just wouldn't go in.. I made sure that the oil pump drive was lined up in the same angle as the counterpart on the distributor... I tried it for over an hour and finally gave up for tonight.. I also tried spraying the gear on the distributor and the gear on the camshaft with WD40 but it didn't help..
It was a pain getting the balancer centered on zero degrees. If I'd bump the starter I'd have to play around with it to line it up again... Don't know of any other way to linke up the distributor correclty...
just bump it and the distributor will drop in when the slots line up...put the car in gear and just bump it, you can keep bumping till the timing marks line up to verify the rotor is at #1 plug. If you lined up the rotor correctly, the distributor will fall into place and the rotor will be lined up to #1 plug
Isn't there a risk that the gear on the cam or distributor could get f'd up that way??
The high torque starter turns pretty fast...
I never knew (until that previous thread) that you could do that. I'd get the teeth lined up with #1, but same thing, the oil pump shaft would hold it up.
Good advice!
I made sure that the oil pump shaft would line up with the distributor... Don't think that this is the problem...
Is the oil pump shaft slot maybe too narrow or small for the distributor gear to "engage" into???
I'd never "bump" the motor to do this. Oliver, you should be able to "feel" the teeth engage, then "ratchet" the rotor backwards a few degrees. You have to remember, even though it appears you have the oil pump shaft lined up, the distributor turns or rotates clockwise as it gets "dropped" in. This is when it will go farther than you think and will overshoot the position of the shaft of the oil pump.
oliver, you may think you have the slots lined up..but if they are off even 5 degrees, the distributor won't drop....
Another point...if the distributor is longer than the stock unit, then you should have been supplied with an oil pump shaft to compensate for the length...did you get a shaft with the distributor?
Any ideas how I can make it go in??
Stick a long screwdriver down the dist hole into one of the slots in the Oil Pump shaft. Rotate the shaft about 1-2 teeth clockwise, then try dropping the dist in again. If it doesn't drop in, move the shaft another tooth clockwise. Keep trying - eventually, it will drop in.
