Distributor won't go in....
Old Feb 3, 2005 | 02:28 PM
  #41
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Big632, I work alone, so I don't have anybody bumping the starter for me. What I do to be sure that I got #1 is by taking the drivers side valve cover off and verify that both valves on #1 are closed. If they are and the timing marker is at 0, I know that I got #1...
Getting #1 isn't the issue..... I've done this several times.. The main issue is that the distributor just won't drop in even with the slot aligned.. Tonight, I'll try to dip the distributor gear in oil and try it again... The gear was already used on the dyno and should work..
Old Feb 3, 2005 | 03:31 PM
  #42
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
do what I did... stand on the air cleaner and stomp on it a few times
Old Feb 3, 2005 | 03:50 PM
  #43
GDaina's Avatar
GDaina
Well Ollie, the only thing I can think of....you sure the bronze gear is on correct? Not reversed?
Old Feb 3, 2005 | 04:13 PM
  #44
GrandSportC3
The bronze gear is installed correct for sure...
Old Feb 3, 2005 | 04:40 PM
  #45
kdf1986's Avatar
kdf1986
Hello
I know the gear is the same one from the dyno test, but is it a different distributor.
kdf
Old Feb 3, 2005 | 05:14 PM
  #46
GDaina's Avatar
GDaina
Quit dickin around and bump the damn starter....
Old Feb 3, 2005 | 05:22 PM
  #47
Fevre's Avatar
Fevre
Damn foreigners.
Old Feb 3, 2005 | 05:23 PM
  #48
soggybottomboy's Avatar
soggybottomboy
Since you have already tried dropping in at every position and it's not going down it really sounds like the gears are not meshing. I assume you have moved the rotor back and forth while trying to get it down in any position? Something doesn't sound right. Can you put some grease on the bottom of the dist gear and verify that it touches/meshes with the cam?
Mark
Old Feb 3, 2005 | 05:28 PM
  #49
GDaina's Avatar
GDaina
You can tell if the gears are meshed...if the bronze gear is on correctly and the gear is deburred, and I assume it is deburred, the distrubutor and the cam gear have to mesh, it's impossible not to mesh....
The only other thing....the oil pump rod may be too big for the bronze gear
Old Feb 3, 2005 | 06:18 PM
  #50
EDDIEJ82's Avatar
EDDIEJ82
Originally Posted by Fevre
Damn foreigners.
Just bump the starter O, it will be alright.
Old Feb 3, 2005 | 07:39 PM
  #51
GrandSportC3
I can't imagine that because the bronze gear has been in the engine on the distributor that they used on the dyno...
I bumped the engine and it would turn but not drop in... I'd like to try to drop in another distributor but I only have the one that I'm using right now...
Old Feb 3, 2005 | 07:40 PM
  #52
GrandSportC3
Originally Posted by kdf1986
Hello
kdf
True...
Old Feb 3, 2005 | 08:04 PM
  #53
comp's Avatar
comp
it can need shim's
Old Feb 3, 2005 | 08:25 PM
  #54
Mr Fanuc's Avatar
Mr Fanuc
Try taking the gear off and see if you can get the dist. to drop. This will tell you if it is the gear or not. If it still will not go down you know where to start. Too many variables you are fighting to know where the problem is. Have the cap off so you can see if the shaft is pushing up through the housing.
