ok so spring time is almost here and i will be working on the car again soon so i need to start ordering parts soon. i am replacing both front lower dash pads and the center guage cluster and want to put in all new guages in the center and also want to put in a new after market speedo and tach but want ones that will fit in the stock location. the only thing that i dont want to go with is the digital guages sense im not to fond of them. and i am also looking at replacing the wiring harness in the car and have no idea what will fit. i would like to switch it over to the new style spade fuses instead of putting in the glass fusses again but if i have to i will go with the glass ones if there arnt any newer style wiring harnesses available.
Since your planning aftermarket guages you could also start with one of these "universal" kits that have newer blade type fusebox, but looks like more work to connect/install:
I've also heard good things about M&H. They have exact fit hanesses but also offer them with updates for internal volt. regulator and/or HEI ignition too. I don't think they offer newer style fusebox though, unless you go with a universal type harness. Here's a link:
