Advise on Diff. Side Yokes Please
Old Feb 7, 2005 | 08:26 AM
jimvette999's Avatar
jimvette999
Default Advise on Diff. Side Yokes Please
I have some significant amount of in-n-out movement on left differential yoke. I put new yokes in not that long ago and the cross shaft retaining the spider gears looked good. Is the excessive play form the clutch pack or spider gears? Where can I get the shims to remove this play or should I replace the clutches? I remember a thread about this not that long ago but I can't find it.
Thanks,
Jim
Old Feb 7, 2005 | 08:33 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Jim,
You can get clutches from any GM dealer. I think they may have the shims as well but if they don't a diff shop should.
Old Feb 7, 2005 | 08:59 AM
jimvette999
Originally Posted by Van Steel
Jim,
Thanks for your reply Van Steel.
I was wondering how to know if it's the clutch packs, the way the replacment axle snap ring grooves were machined or worn spider gears. I don't know which area to correct, all I do know is that the axles aren't worn down on the ends and the cross shaft was not worn. There is approx. 1/2" of in-n-out movement on the drivers side. How much movement should there be?
Old Feb 7, 2005 | 09:01 AM
norvalwilhelm's Avatar
norvalwilhelm
Jim,
The GM dealer is rediculous for posi clutches, $175 Canadain. The side gear shims are also too pricy at the dealer $110CDN.
But yes tightening up the clutch pack as well as the spider gears can quickly take .050 out of the yoke end play.
Old Feb 7, 2005 | 09:02 AM
norvalwilhelm
No way you can get 1/2 inch of play from a yoke unless the pin is gone or no clip is in place. The clip is only about .190 from the end to begin with.
Old Feb 7, 2005 | 09:24 AM
fmann87's Avatar
fmann87
7th Gear
I just did this job and I had .04" play on each side yoke. My yokes and pin were not worn. I found my clutches were worn. But its hard to understand where you are getting .50" play unless a previous owner left out the clutch shims and several plutch disks. The spider gears will not effect this side play. I ordered a clutch pack with a full set of shims for about $85. from Tom's differentials(tomsdifferentials.com).
Old Feb 7, 2005 | 09:26 AM
jimvette999
Maybe it's a 1/4"....I know it's excessive. I need to drop the rear end out, open it and get some real measurements with a dial indicator. What is the ideal amout of movement?
Old Feb 7, 2005 | 09:35 AM
fmann87's Avatar
fmann87
7th Gear
I got mine to about .008" using the shims from Tom's. Any tighter and the spiders gears started binding. As to how much you should have, I've never found a answer to that. I've searched numerous forum threads and it seems about .05" - .06" is where you should be concerned. You can measure end play without removing the diff. Disconnect the 1/2 shafts at the diff then use a dial indicator with a magnetic base.
Old Feb 7, 2005 | 09:42 AM
jimvette999
thanks for the help guys
I know I could measure the play while diff. in the car but something is wrong so I might as well put it apart and find the problem. I just wasn't sure which to blame the problem on since the spider gears looked good, the posi worked good and the yokes were new.
Old Feb 7, 2005 | 10:11 AM
norvalwilhelm
Spider gear clearance definitely affects side play of the yokes. If the clutch pack is warren and the side gear shim is too small the clutch pack can compress allowing the yoke with it's retainly clip to pull out more towards the outside of the car.
If the clutch pack is tight it also takes clearance out of the spider gears causing less backlash in the spider gears and at the same time reducing yoke free play.
I learned alot in the last month from Gary and by doing the job and one thing I really learned that spider gear backlash is important to yoke clearance. I play with a rearend over a couple of weeks doing and understanding why/how it worked.
Spider gear clearance is important and something that I overlooked all the years of building rearends.
It took Gary and carguy4sure to point this out to me and teach me what is important.
Don't overlook the spider gears.
Old Feb 7, 2005 | 10:25 AM
jimvette999
Norval, can you recommend the spider gear backlash measurement and the side yoke tolerance I should aim for? I put the yokes in at the same time I put a new ring and pinion in and I inspected the cross shaft and saw no wear. My guesstimate of 1/2" was probably wrong, 1/4" is probably closer.
Old Feb 7, 2005 | 10:30 AM
norvalwilhelm
I would shim each side gear/clutch pack seperately so when a chissel is put between the axle gear and the pin the spider gears are just about binding, not quit but close,. Do one side seperate then the other side . For final assembly assemble both sides. The spider gears with the chissel compressing the clutch pack should barely move, a couple of thousand backlash.
The yoke end play in below .010 maximum.
It works guys if the axle gears are shimmed right
Gary knows more about this then anyone else. Well not anyone but he is very very knowledgable on this subject.
Old Feb 7, 2005 | 10:32 AM
GTR1999's Avatar
GTR1999
Jim, I'm going to IM you my number maybe I can walk you through the job without typing another 3 pages
Gary
Old Feb 7, 2005 | 10:40 AM
zwede's Avatar
zwede
Spider gear play should be approx 0.002". This is hard to measure but if you set it up so that you can just barely feel the play you're at 0.002.
Each side is set up independently. Then you should be able to just drop the pinion shaft in with no effort. If it is hard to insert one side is off and you need to reshim.
Once this is done the yoke end play ends up in the 0.005-0.010 range (with new yokes, of course).
Old Feb 7, 2005 | 10:55 AM
jimvette999
thanks again guys
I'm going to pull it apart this weekend and see what's wrong and pester gtr1999 (Gary) for help when he's available.
Old Feb 7, 2005 | 11:18 AM
fmann87's Avatar
fmann87
7th Gear
Norval, I agree that spider gear tolerance will effect yoke side play when setting up the diff. In his initial post he talked about spider gear wear. The spider gears wearing would not cause excessive yoke play. Thats why I said that his spider gears have nothing to do with his excessive play. Maybe I should have said his spider gears did not cause his excessive play. I've read many of your threads and appreciate your advice. Thanks, Frank
Old Feb 7, 2005 | 12:08 PM
norvalwilhelm
My fault Frank. I didn't read your post closely. You are right.
Zwede made a good point. Set up tight the pin still falls right into place with little effort. Amazing that after all the trying to compress the clutch pack and the shimming the pin just slides in.
He is also right if the pin is hard to install it is because one side is off.
Old Feb 14, 2005 | 08:56 AM
jimvette999
Default UPDATE: Pulled the rearend out this weekend
Well, I guess I really overestimated the axle play :o it looked like a lot more that it was. 0.059 rt and 0.048 lt. Still too much but not the 0.50 I originally thought guessed. I also found that the cross shaft is worn out the carrier pretty badly. I have to put another carrier in so I guess I'll be starting from scratch on setting all the tolerances. I'm going to contact Gary (gtr1999) to see where to get a carrier, clutches, cross shaft and retaining bolt for cross shaft. I also found that one of my outboard ujoints is binding a little bit. The spicers I installed should not be failing this soon so I think the ujoint housing needs replacement. Anyone know where I can get complete driveshafts with solid ujoints already installed? Having them pressed in without a fixture is apparently not working.
Thanks,
Jim
To Advise on Diff. Side Yokes Please
