How difficult is an engine swap?
Old Feb 7, 2005 | 07:39 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default How difficult is an engine swap?
I'm swapping the tired L-48 out of my '80 for the GM LM1 Engine.
How difficult is it for a first timer?
What type of equipment do I need?
Can I do it by myself?
Do I need a lift?
TIA, Les
Old Feb 7, 2005 | 07:41 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
You need a cherry picker and a load leveler, which you could probably rent. It is a LOT easier with 2 people, but doable with 1 if you are carful.
Good luck.
Old Feb 7, 2005 | 07:45 PM
1Bad69's Avatar
1Bad69
Les,
Mike did his in a day and a half...ask him about it...
Old Feb 7, 2005 | 07:54 PM
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
I would'nt recommend it for a first timer with limited tools/equipment. Get some help via friends who have done it and are commited to you throughout the process.
What are going to do with the old engine?
Old Feb 7, 2005 | 08:00 PM
AGVI's Avatar
AGVI
I'm keeping the old engine in storage.
Old Feb 7, 2005 | 08:09 PM
1Bad69's Avatar
1Bad69
what are the specs on this one? i thought you were going for some serious power?
Old Feb 7, 2005 | 08:16 PM
johnt365's Avatar
johnt365
I just installed a 350 in my 74. I bought a lift for $175. and the install took about 40 minutes. I had one other person help me and I can tell you for me it would have been very frustrating to do it by myself but not impossible. Once I got all the bolts installed (mounts and transmission) I went back and put locktite on them one by one and tightened them in. my two words of wisdom would be one to get help simply to line things up while you put the bolts in. and, if its an automatic, make sure you get the torque converter installed all the way to the back almost touching the front pump on the trans. it wasn’t hard at all and aside from the lift, can be done with a couple of sockets and wrenches.
Have fun with it.
Old Feb 7, 2005 | 08:30 PM
stpman's Avatar
stpman
When I got my 74 a friend and I pulled the engine out and put my new one back in about 4 hours, he spent another 4 finishing and starting it to break in the cam. the car was on my trailer which gave us room under and wasn't too high to lift the engine out.
Steve
Old Feb 7, 2005 | 08:57 PM
AGVI's Avatar
AGVI
It's 265hp. I'll live with it until the warranty expires (3 years), then I'll swap the heads/cam to bump it up to 400hp.
265 is a lot better than the 190 it's not even pushing now and you can't beat the $2195 Canadian price tag.
I gave up on crazy HP dreams. I realized that I don't drive aggressively anyway, so why spend $10,000 on a ZZ5 and $6,000 on a six speed tranny?? All I really need is about 350-400hp and my rebuilt TH350 and rear diff. Car is done for me!!
I must be calming down in my old age!!!
Les
Old Feb 7, 2005 | 09:06 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Had a helper when pulling the engine and installed the new engine and transmission myself.. Not really a difficult job.. Can be done alone with the right equipment.. Cherry Picker and tons of other standard tools are needed..
Old Feb 7, 2005 | 09:10 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
How close is close?
It's a big job, but doable...
Old Feb 7, 2005 | 09:20 PM
GrandSportC3
Originally Posted by 427V8
How close is close?
It also depends a lot on how many accessories somebody is running... Except the standard items, I had no accessories on my engine.. so it went pretty quick.. Took 3.5 hours to pull engine and transmission.. Installing took a little longer than that..
Old Feb 7, 2005 | 10:09 PM
1Bad69's Avatar
1Bad69
i have to ask...why wait for the warranty to expire on the new engine when you already have a 350 in it? take the cash you spent on the crate and dump it into the one you have now?
or are you thinking about keeping it original? the motor i mean?
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
An extra couple of pairs of hands would be helpful too. Especially lining up to the tranny.
Buying a hoist is really more convenient than renting it. I would have had to rent a hoist 4-5 times when I did mine. At $35-40 a pop and no telling if the hoist will be at the shop when you need it.
Old Feb 7, 2005 | 10:15 PM
AGVI's Avatar
AGVI
Why not get a brand new engine with warranty instead of spending money on an old engine? Rebuilds are more expensive than the cost of a new crate....and peace of mind is priceless
Old Feb 8, 2005 | 12:24 AM
Berserker78's Avatar
Berserker78
I am looking at that same engine to swap into my 78.
How hard is it to get the torque convertor lined up? Do you have to drop the transmission to get the engine in/out?
Old Feb 8, 2005 | 12:48 AM
lostpatrolman's Avatar
lostpatrolman
You can leave the trans connected to the engine and pull them out as 1 unit if you want.
To How difficult is an engine swap?
Old Feb 8, 2005 | 12:50 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
I put that same motor in my '75 last summer & have over 500mi on it now-would've put much more on it, but the weather started turning bad and didn't want to take the car out. Had it out a few times during the winter when the roads were nice, dry & clear of salt.
That motor runs super smooth in my car Spent about 4hrs taking the old one out and a couple hours putting the new one in. Did it with a lift all by my lonesome. Not hard at all. I put the motor/tranny in as a unit, but I also had my radiator & coresupport out at the time, so I had plenty of room.
Old Feb 8, 2005 | 03:40 AM
jaychis's Avatar
jaychis
It's a piece of cake if you lift the body
Old Feb 8, 2005 | 07:59 AM
markdtn's Avatar
markdtn
Not a horrible job, you gotta learn sometime. Take your time. Get a friend (or more) to help with the actual in and out.
