Power Steering Ram
Old Feb 8, 2005 | 12:27 AM
Berserker78's Avatar
Berserker78
Default Power Steering Ram
My power steering ram has started leaking pretty significantly. Six months ago, it didn't leak at all, but it have been sitting since then (winter), and when I went out to start it today, I drove it in a circle around the parking lot to get everything loose before parking it again, and I discovered that the power steering ram is visibly leaking.
I am going to try using some stop leak fluid in it, but if that doesn't work, how large of a project is replacing it?
Old Feb 8, 2005 | 12:32 AM
Retro78's Avatar
Retro78
Replacing it is easy, just messy. I would not bother with a stop-leak product. Once the seals go, time for a new one. You may also want to consider installing new hoses at the same time.
Old Feb 8, 2005 | 02:24 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
I just did this job 2 weeks ago, order the complete kit, which includes the control valve, the cylinder, and 4 hoses...(you WILL need new hoses)...
Just keep the orientation of the hoses from the control valve to the cylinder correct...
You will need a pickle fork to get the old parts off, the rest is just regular hand tools. After all the nasty greasy old parts are off, all the new shiny parts go on real easy...
No more drips now :
Old Feb 8, 2005 | 11:38 AM
Matt Gruber's Avatar
Matt Gruber
if u have snap ring pliers, u can change the seal.
i paid $12 for a kit. all i used was the seal.
that was 10 years ago and not a drop has leaked since.
Old Feb 8, 2005 | 03:50 PM
COMMANDER370's Avatar
COMMANDER370
I had more trouble getting mine off my car than the guys here at work did fixing it.I bought the kit and got it rebuilt for a 6 pack after work I agree in repacing the hoses
Old Feb 8, 2005 | 09:13 PM
68/70Vette's Avatar
68/70Vette
After removing the snap ring, I didn't find it that easy. There were other washers remaining and to get them out I had to sharpen a small screwdriver and cut the pieces to remove them. Yes, with these kits you can replace the washers under the snap ring. But these aren't the only washers and seals. There are others inside the body that you can't reach without cutting the cylinder open. If you solved your problem by replacing the washers under the snap ring, that was a good reason for trying the rebuild kit. However, I think it should be recognized that for some seal failulres, replacing the washers underneath the snap ring may not be the solution. My impression was that the seals under the snap ring were really just mud scrapers. Possibly I'm incorrect about this. I, like you, have preplaced my seals with the kit you probably used. I'm just hoping it really works.
To Power Steering Ram
