Street roller vs true roller timing chain
Old Feb 8, 2005 | 07:50 PM
75 Hot One's Avatar
75 Hot One
Default Street roller vs true roller timing chain
Does anyone know what the difference is and how do you tell the difference by looking at them?
Old Feb 8, 2005 | 07:52 PM
joe73vette's Avatar
joe73vette
I think the rollers on a true roller are bigger, and/or the chain is wider. I think you have to see them side by side. Joe
Old Feb 8, 2005 | 09:22 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Depending on the terms being used a true roller generally means that there is a pin connecting the links of the chain and a roller that goes over the pin thus rolling as the chain runs over the sprocket. A 'street' roller just has the pins. The overall dimensions of either are the same and that is .25" diameter pins or rollers. When you get a true roller be certain that it isn't a split roller, meaning the rollers are made with a seam in them. These types are prone to failure under extreme conditions because the seam is the weak point. Get a true roller with seamless rollers if you want the best quality. They, of course, are much more expensive than a normal 'street' or split roller chain.
Oh, one more point....true rollers are sometimes called double rollers but don't confuse them with double row chains. You can have a double row, double roller chain (most are) that is also a double row true roller chain. As always people misapply the terms and call double row chains a double roller. So have a close look at what you buy or a general rule is if it costs around $90 US or more then it is probably a true roller. When you look at the chain use a point of a pen to try to spin a roller. It it's a solid pin then it is a 'street' type roller but if there is a sleeve that rotates then it is a double or true roller. As an example jeg's/cloyes p/n 220-9-3145 is a true roller with rotating pins/rollers but p/n 220-9-1100 is a 'street' roller with solid pins/rollers.
To Street roller vs true roller timing chain
