New block vs Old
Old Feb 8, 2005 | 06:11 PM
zgate's Avatar
zgate
6th Gear
Default New block vs Old
What is the difference between an 87 and up block and a 1969 block as far as parts fitting? Timing chain cuover, flywheel etc,
Old Feb 8, 2005 | 06:25 PM
C3w4sp's Avatar
C3w4sp
One piece rear main seal, different crank, different flange = different flywheel bolt pattern = different flywheel.
Best thing is, there are some threaded bosses in the lifter valley that hold down a sheet metal "spider" that holds factory roller lifter retainers. Basically roller cam ready!
At some piont (early to mid 90's) there is no hole drilled for the fuel pump push rod if you want to run mechanical fuel pump.
I used a salvaged block, it had the tins with it so I'm not sure about the timing cover.
Old Feb 8, 2005 | 06:30 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
'65-90 (maybe 91 not sure) are Mark IV blocks. I have an '87 454 and used 65-90 parts.
90/91 started the next generation.
Old Feb 8, 2005 | 07:57 PM
markdtn's Avatar
markdtn
Depends if you are talking BB or SB.
On the SB, flywheels are different due to the 1-pc seal, oil pans are different. Other than that most everythng else interchanges. Motor mounts are same, all holes in same basic place. Balancers interchange, as do starters, pistons, and rods. Not sure about the timing cover, it may be the same as late-70s up. Basically it is a bolt in swap if you have at least a short-block plus flywheel or flexplate.
To New block vs Old
