O2 Sensor Thread Pitch
Old Feb 9, 2005 | 12:47 PM
FLEXUSMARK's Avatar
FLEXUSMARK
Default O2 Sensor Thread Pitch
I am getting my headers coated soon and I was thinking of adding an O2 weld bung for a A/F gage.
I am not ready to buy the sensor and gage at this time so I was thinking of making my own weld bung and welding it in before coating. I know that the thread is 18mm but I don't know the thread pitch.
Does anyone?
Thanks.
Mark.
Old Feb 9, 2005 | 01:07 PM
timbo79's Avatar
timbo79
Sorry I don't know the pitch, but most all 02 sensors are the same. You can get an 02 bung with plug from Summit or most any parts store for around $20 US. This way you can plug the bung until you get the sensor installed.
Old Feb 9, 2005 | 01:09 PM
mrtroutjedi's Avatar
mrtroutjedi
and they also sell the plug for it.
Old Feb 9, 2005 | 01:44 PM
flood's Avatar
flood
Going wideband?
Regular 02 sensors suck and it wouldn't be very much use to you.
Old Feb 9, 2005 | 01:56 PM
zwede's Avatar
zwede
Easy solution: Go to most any autoparts store to the "help" section. Look around and you should find what they call "spark plug anti foulers". These are just spacers. One end screws into the plug hole in the head, other end you put your spark plug. They will have the smaller version as well as the large spark plug version (18mm). Get the larger one as it is the same thread as an O2 sensor. Cut the "anti fouler" in half and weld it to your header.
Old Feb 9, 2005 | 02:12 PM
FLEXUSMARK's Avatar
FLEXUSMARK
Originally Posted by flood
Going wideband?
What do you mean by "Going wideband"?
And why do "Regular O2 sensors suck"?
I was planing as using it as a tuning aid.
Old Feb 9, 2005 | 02:24 PM
mooneyd's Avatar
mooneyd
The standard pitch for a 16mm thread is 1.5mm
Old Feb 9, 2005 | 02:32 PM
FLEXUSMARK's Avatar
FLEXUSMARK
Did you mean 18mm
Old Feb 9, 2005 | 03:33 PM
flood's Avatar
flood
Sorry I was very vague.
narrow bands only read up to 1 volt and a wide band reads up to 5 volts. wide bands are much more accurate when tuning a car
Narrowband O2 sensor outputs 0-1 Volt. The higher the voltage, the richer the air/fuel ratio. The problem with a narrowband is that it has an "accuracy window" which means it is accurate ONLY from 14.3:1 - 15.3:1.
A good wideband sensor can read from 10:1-20:1.
Old Feb 9, 2005 | 04:40 PM
Scooter70's Avatar
Scooter70
I just checked a bung that I have in the garage and the thread pitch is 1.5.
For tuning, you need a wideband. Check out either the Dynojet Commander, the Innovative Motorsports LM-1, or the AEM. As was said above, narrowband sensors are only really accurate at 14.7:1. The wideband will tell you how rich or how lean your mixture really is.
Old Feb 9, 2005 | 04:56 PM
Fevre's Avatar
Fevre
Wide bands are great for EFI but for a carb are overkill, change the air temp and your accuracy is shot with a carb since it can't adj. Why spend big $ for a wide band when you can get all you need from a heated O2 sensor?
Old Feb 9, 2005 | 05:28 PM
Older Than Dirt's Avatar
Older Than Dirt
Glad to hear that! That's what I thought too, so I bought the heated sensor but haven't installed it yet.
Old Feb 9, 2005 | 05:42 PM
Fevre's Avatar
Fevre
I have an Edelbrock one and it works fine for my carbed vette, since 14.7 is where it is most accurate once you find 14.7 you just adj a little leaner or richer depending on what you are shooting for.
Old Feb 9, 2005 | 06:03 PM
Matt Gruber's Avatar
Matt Gruber
Default it's the most fun gauge in my 72
on a cold start i can watch it go lean and pump it before it begins to stall(no choke)
Old Feb 9, 2005 | 06:44 PM
flood's Avatar
flood
< insert reasons why FI rules here >
To O2 Sensor Thread Pitch
