piston to wall clearance
Old Feb 10, 2005 | 08:27 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Dial bore gauge is the only thing to use and it is not that expensive
mandm1200's Avatar
mandm1200
Originally Posted by Twin_Turbo
What?? You measure the piston skirt diameter w/ a set of vernier calipers first and then the bore w/ a bore gauge, the difference is your clearance.
If you do it that way, you did not measure the piston to wall clearance, you calculated it. There is a big differnce between measuring and calculatiing it.
Old Feb 10, 2005 | 08:35 AM
Twin_Turbo's Avatar
Twin_Turbo
Well...without going into the detail o the correct denomination of the procedure...that's how it's done correctly. And if you want to discuss errors, there's 2 measurements errors, one for the bore measurements and 1 for the piston measurements, the calculation does not introduce another meaningful propagating fault into the total (because the error is smaller by 1 significant number than the measuring errors, the rounding off/reading is already done there) so you measure 2 dimensions...calculating is just part of the process....
Old Feb 10, 2005 | 08:41 AM
norvalwilhelm's Avatar
norvalwilhelm
You don't measure bore clearance. You calculate it. You measure the piston diameter, the bore diameter and subtract the two for piston wall clearance.
I have a proper bore gage and you just mike the piston and regardless of what it reads set the bore gage to this value, it is just a dial gage that you zero using the mike on the piston to find zero, Anyway you zero the gage and then put it in the bore and the difference between the zero you set on the gage and the new reading on the gage is the piston to wall clearance.
Feel gages are for setting valves and NOT for piston to cylinder wall or bearing clearance.
Old Feb 10, 2005 | 08:51 AM
mooneyd's Avatar
mooneyd
I wouldn't use a feeler gauge, the feeler is a flat strip of metal, if you use it to measure bore to skirt clearance the strip actually has to bend and even though it will bend it may not be willingly enough to bend to allow the feeler(s) with the exact clearance thickness to be inserted meaning you can just slide in one that's a tad smaller, this will lead you to believe you have a tight clearance when in all reality it may be slightly larger...and it's not inches we're talking about here. If you are serious in building your engine be prepared to spend some money to buy a bore gauge, you don't use a hammer to remove and install a damper also so why not use the proper tools to measure critical dimensions.
You can't measure between two curved surfaces with a flat feeler gage. Also, if you measure that way from one side the piston can move because of the clearance on the opp. side. It does not take any special skills to read a mic or a vernier, especially the digital ones.
Matt Gruber's Avatar
Matt Gruber
Default Great Topic
there are at least 3 types of feeler gauges, only 1 is for valves.
Norval
please tell how you check ring side clearance.
(others feel free to chime in)
i build my motors without any binding that could ruin them. the lowly feeler gauge has prevented disaster several times. once i found a tight spot on a piston, that on close inspection appeared to have been dropped. a mic would have missed that!
i'm glad my auto shop teacher,in 1970, showed the class all the things to measure with a feeler gauge. i've never had a blown up engine in 35 yrs.
Old Feb 10, 2005 | 10:02 AM
Paul @ Thunder's Avatar
Paul @ Thunder
We build a lot of motors here and we stand behind them and warranty them. There is no a way a motor would leave this shop with anything other then valve lash measured with a feeler gauge. Our blue print sheets are accurate down to the hundred thousandths and include every measurement of the engine from rod bolt stretch (not torque) to the Ra of the cylinder walls, block, and head surfaces. There is one correct way to do it and another way that will work too.
Old Feb 10, 2005 | 10:07 AM
mandm1200's Avatar
mandm1200
I don't think anyone who used a feeler gauge would say with absolute certainty that is is wrong to calculate the clearance with calipers and bore gauge. Personnaly, I think that is a proper way to do it. Not only has someone said that a feeler gauge is not the best way to do it, that it was wrong.
I also believe the the feeler gauge is also proper. Feeler gauges come in different widths as well as thickness. The thin blades do bend to fit between piston and wall. There is a margin of error no matter how it is done. As long as measurement with error is within the tolerances set by the manufacture of the product, then these two methods should be acceptable.
Old Feb 10, 2005 | 10:32 AM
norvalwilhelm
Norval
Matt your right I use feeler gages for measuring ring end gap but that still doesn't make it right for measuring piston clearance. Sure you are quaranteed the clearance is greater then the feeler gage but how much??
If I want .0045 clearance that is what I want and not something greater then a .005 feel gage.
Machine shops all know me and know I take my own mikes to check their work. I never agrue about the price, mostly tip a little extra but I demand exact work and I get it.
The forman usually take care of me personally. He know I know good workmanship and will be checking.
Old Feb 10, 2005 | 10:43 AM
lars's Avatar
lars
Norval -
Good to see someone knows correct way to check tolerances. Like you, I have my own dial bore gauges and a set of mic's. I check every bore and every piston on every engine I put together. There's only one right way to measure the clearance of a piston in a bore - I can't believe there's even a discussion about it here. I've been involved in aerospace machining and measuring operations for 30 years. To check fit of a piston in a bore, you mic the piston and measure the bore with a bore gauge. Period. The piston is measured at the skirt (below the ring land and above the bottom edge) with a micrometer - not with dial calipers (and not with a feeler gauge).
Old Feb 10, 2005 | 10:51 AM
Matt Gruber
Norval
do you ever check ring side clearance?
my old pistons were .004", WAY over the .002" stock. that motor got new pistons.
.(not talking end gap).
i am not suggesting a machine shop use only feeler gauges(they don't have the time)!
On mock up assembly feeler gauges tell the true story
WILL IT SPIN FREE OR BIND (when hot)
feelers are a final GO/NO GO test.
my feelers can only read in 1/2 thou. .001. .0015, .002 .0025 .003 .0035
That is close enough to CHECK THE WORK of a shop.
Old Feb 10, 2005 | 11:13 AM
norvalwilhelm
Norval
I have go / no go gages for the valve quides in .0005 increments and check guides for 1/2 a ten thousands clearance but not for anything else.
With the mics are also proof rods, I check the mike against them often and even the temperature of the mic and pistons must be the same.
Not everyone can measure properly with a mic. a vernier is definitely out for measureing. It takes alot of practice to really use a mic properly but with a bore gage you don't actually care about the reading only the diffence which the dial indicator on the bore gage reads. The mic is only used to zero the bore gage.
And again Matt I was wrong, feeler gages have their place like ring gap, ring side clearnace but not where we are working in 1/2 thousands.
Old Feb 10, 2005 | 11:14 AM
  #33
Paul @ Thunder
Paul
Old Feb 10, 2005 | 11:42 AM
  #34
Matt Gruber
sure beats talking to the neighbors!
coming soon:
heated dscussion on bearing crush!
Old Feb 10, 2005 | 11:52 AM
  #35
Paul @ Thunder
Oh fun, fun.
Paul
Old Feb 10, 2005 | 11:54 AM
  #36
norvalwilhelm
coming soon:
Looking forward to it. My son taught me alot about measuring bearing preload and I will bet 99% of the people here don't know positively how to measure bearing end play.
Sticking a dial indicator on the end of the axle for example and then pushing in and pulling out and reading the difference is wrong and will be about .004 out from the true reading.
Old Feb 10, 2005 | 11:58 AM
  #37
ZD75blue's Avatar
ZD75blue
coming soon:
Thats something I've been wondering about...
The Vernier Caliper you speak of TT... I've only see this type of digital read out:
I have a dial caliper, but I've always been under the impression that they are only accurate to 1-3 thousanths where as a micrometer is accurate to the 10th of a thousandth?
All of a sudden I'm not as confident to just slap my parts together and call it done!
To piston to wall clearance
Old Feb 10, 2005 | 11:59 AM
  #38
ZD75blue's Avatar
ZD75blue
I havent got a clue how you do that...
Old Feb 10, 2005 | 12:10 PM
  #39
stingr69's Avatar
stingr69
I can't believe this thread either. If someone was asking this question here, they obviously do not have a bore gauge in the tool box in the first place. How did I get re-directed to the NCRS board?
If you want the NASCAR quality job, take it to a qualified shop, pay the spcialist to have the job done "Right". Otherwise find a shade tree, a feeler gauge set and have at it.
There is always a "right" way to do a job but for practical purposes there are other ways of getting "close enough" for us amatures.
-Mark.
Old Feb 10, 2005 | 12:15 PM
  #40
vette rod's Avatar
vette rod
You are lost! I would love to leak one of your engines down.
u don't measure piston to wall clearance with a bore gauge, do u? u must be joking
The micrometer salesman REALLY sold u guys. Prolly sold u a ring side clearance mic too!
